Vixen Turret and refractor connexion
5 replies to this topic
#1 pancho61
pancho61
  • Loc: France, D Day beach
Posted 26 May 2020 - 06:31 PM
Hello,
I have bought an vixen/celestron turret who has ben originally design for SCT, i have plan to use it with a refractor for eyepiece comparaison. Thread of this turret is for sct so i must do somes modification to adapt this turret in 1.25" or 36.4mm Vixen connection. I try to found some adapt to do this job but it is really hard to find it, does anyone already done this adapt? I will share some picture who show the turret and some measure ( sorry it in metric). On this turret you have two thread one is 39mm and the other is 37.4mm approximately.
Thanks for your help
clear skies
#2 Don Taylor
Don Taylor
  • Loc: Broken Arrow (Tulsa Area) Oklahoma
Posted 26 May 2020 - 10:01 PM
I have not done exactly this conversion - but I believe the following 2 Baader components would work in conjunction with the SCT thread:
SCT thread to T2:
https://www.baader-p...2-part-28).html
T2 1.25 nosepiece
https://www.baader-p...2-part-14).html
I'm not aware of any commercial adapters to mate with the 39mm & 37.4mm threads. Of course a machine shop could build one if needed
#3 pancho61
pancho61
Posted 28 May 2020 - 02:01 PM
Thanks don for your answer, i will try your solution maybe i can use this one two:
https://www.baader-p...cal-length.html
#4 Don Taylor
Don Taylor
Posted 05 June 2020 - 08:24 PM
Damien:    Your Celestron turret is 2 inch SCT thread?  The knurled ring your thumb is touching in the first photo is 2 inch SCT internal thread like for a C8 telescope?
If so, the first Baader adapter in post #2 would thread into the knurled ring - the outside thread is 2 inch SCT, the inside thread is T2.  The second adapter is a 1.25" nosepiece with T2 threads - it is threaded into the T2 internal threads of the first adapter.
Sorry - I don't understand - did you remove the knurled ring to reach the  39mm and 37.4mm threads?  My suggestion would retain all of the original turret parts plus add the two Baader adapters.
I apologize for my lack of understanding here.
Edited by Don Taylor, 05 June 2020 - 08:25 PM.
#5 Nippon
Nippon
  • Loc: Central Florida
Posted 06 June 2020 - 04:36 PM
Check with Moonlight. I seem to remember they made an adapter to use SCT accessories with refractor focusers.
  • pancho61 likes this
#6 pancho61
pancho61
Posted 07 June 2020 - 05:31 PM
Thanks for your reply i will ask to this member!!!!
