solar proms with my spectroscope lately
solar
5 replies to this topic
#1 chrishalpha2017
chrishalpha2017
  • Loc: Paris
Posted 26 May 2020 - 11:01 PM
Hello guys,
the sun's still shining here in Paris and despite partial lockdown I can still watch the sun with my spectroscope through my little window under the rooftop smile.gif
Here are some recent pics  but this time I wanted to experience the Secchi experience with a 600 l/mm diffraction grating instead of the 1200l/mm grating that I usually use..
Secchi described in his book that he was given a grating by rutherford and that the dispersion gave him the dispersion of his 7 prisms spectrocope : the grating had about 600 l/mm and the collimator focal lenght is 130mm (mine is 180mm).
The results are interesting : the image is more detailed even though I have to open the slit less wider. An interesting fact compared to the use of the 1200 l/mm is the fact that the chromosphere "ribbon" is much less thinner and that the spicules are more easily seen.
  • old_frankland, hopskipson, Gray and 8 others like this
#2 UniversalMaster
UniversalMaster
Posted 27 May 2020 - 02:47 AM
Very nice! Do you have a full spectrohelioscope or do you just let the sun scan across the slit and assemble the line spectrograms?
Which spectroscope do you use?
#3 chrishalpha2017
chrishalpha2017
  • Loc: Paris
Posted 27 May 2020 - 06:25 AM
https://youtu.be/or12v5vBTzY
I just use a spectroscope (homemade) with a 1200l/mm  reflection grating. There is no scanning ;  I use Angelo Secchi 's technique from his book "Le Soleil".
You just have to manage to have the slit of the spectroscope tangent to the sun's limb and observe the h alpha line in the spectrum.
Edited by chrishalpha2017, 27 May 2020 - 06:30 AM.
#4 chrishalpha2017
chrishalpha2017
  • Loc: Paris
Posted 27 May 2020 - 06:32 AM
here is a drawing from his book that explains how it works
You can use a thin slit to detect the presence of the prominence and then; if the sky is clear enough you can open the slit a bit more to see the prominence completely.
#5 UniversalMaster
UniversalMaster
Posted 27 May 2020 - 08:59 AM
Yes, that is pretty cool. I tried this once
http://www.astrosurf...romo/chromo.htm
when my spectroscope was functional. Plan was to build a complete spectrohelioscope, but I never managed to do so :-)
The solar spectrum by itself is actually pretty nice looking in an eyepiece!
#6 chrishalpha2017
chrishalpha2017
  • Loc: Paris
Posted 08 June 2020 - 01:23 AM
yes, its  the same technique but they lack high definition a lot as they didnt sample properly at the time ; it was just an experiment they tried :)
This website is pretty old and it inspired me a lot then to make my own :)
Also tagged with one or more of these keywords: solar
