Issue with darks on ZWO
4 replies to this topic
#1 jvaboyjunior
jvaboyjunior
Posted 29 May 2020 - 08:55 PM
Hi there,
I am taking darks on a ZWO ASI183MC Pro and have a starburst pattern on the right of all the images. I have attached the relevant part of a stretched dark capture. This is taken lens cap on, sensor at -10 degrees, exposure is 120s. My first thought was maybe there's a light leak so have just tested again inside a dark bag - same result. This does not show up on bias exposures at 1/1000s.
Is this an issue or does it not matter as stacking will remove it?
Advice much appreciated.
#2 DSOs4Me
DSOs4Me
  • Loc: New Jersey
Posted 29 May 2020 - 09:12 PM
Normal Amp Glow. You an see it here  https://astronomy-im...s-amp-glow.html
  • dswtan, drd715 and TXDigiSLR like this
#3 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 29 May 2020 - 09:44 PM
Typical, normal dark calibration should remove it, but darks must of same temp (no problem w/ cooled), same gain, and same exposure time.
  • drd715 likes this
#4 jvaboyjunior
jvaboyjunior
Posted 30 May 2020 - 10:12 AM
Brilliant, thanks!
#5 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 30 May 2020 - 11:56 AM
As others have mentioned -- entirely normal.
Just be sure when you calibrate your images to turn OFF any "dark frame scaling" or "dark frame optimization" options.  And everything will be fine.
  • SilverLitz likes this
