My brain is stuck on this one
4 replies to this topic
#1 Huangdi
Huangdi
Posted 30 May 2020 - 05:55 AM
I'm sort of confused right now, perhaps someone can help out?
If I have one 80mm Scope with 480mm focal length, that leaves me with a focal ratio of F6
If I have two 80mm scopes with 480mm focal length, I have two scopes at F6.
If I have a 160mm scope with 480mm focal length, I have one scope at F3
F3 gathers 4x as much light as F6, right?
But two F6 scopes only gather 2x as much?
It's probably plain and obvious, but I'd like some confirmation!
Edited by Huangdi, 30 May 2020 - 05:56 AM.
#2 ChrisWhite
ChrisWhite
  • Loc: Colchester, VT
Posted 30 May 2020 - 06:12 AM
Yes.
Remember that it's not just the diameter of the scope that has doubled when you went from 80mm to 160mm, but that the area of the scope has quadrupled.
π*r^2
area of your 80mm f6: 5026mm
area of your 160mm f3: 20106mm
So two f6 scopes would give you 10052mm of area, which is still half of what the single 160mm f3 scope provides.
Edited by ChrisWhite, 30 May 2020 - 06:16 AM.
  • Huangdi likes this
#3 terry59
terry59
  • Loc: Colorado, USA
Posted 30 May 2020 - 06:16 AM
I'm going to avoid the "which way is better" perspective and focus instead on the difference between running one scope and having a dual setup. The latter has a lot of additional challenges to overcome to pull off. Unless your question is purely academic of course
Edited by terry59, 30 May 2020 - 06:17 AM.
#4 ChrisWhite
ChrisWhite
Posted 30 May 2020 - 06:18 AM
It might be less challenging to get two (or four) f6 scopes pointing at the same spot producing nice round stars than a single f3 scope! lol.giflol.giflol.gif
Edited by ChrisWhite, 30 May 2020 - 06:19 AM.
#5 Huangdi
Huangdi
Posted 30 May 2020 - 06:19 AM
Thank you for clarifying, I thought so!
