Zwo eaf question
11 replies to this topic
#1 Spacedout again
Spacedout again
  • Loc: Indiana
Posted 30 May 2020 - 09:48 AM
I recently received a zwo eaf and after getting everything setup I started wondering if its possible to connect the eaf USB cable to my asi533 USB slot?
The camera and focuser are both a new thing for me. Aside from setting up in the house and getting everything communicating with APT and Phd2 they're waiting for first light.
I'm just hoping to eliminate a hanging cable and maybe free up a USB slot on my laptop.
Thank you and clear skies.
#2 ChrisWhite
ChrisWhite
  • Loc: Northeast USA
Posted 30 May 2020 - 09:52 AM
Yup
  • Spacedout again likes this
#3 OhmEye
OhmEye
  • Loc: Western NY Southern Tier
Posted 30 May 2020 - 10:48 AM
I connect my EAF and EFW to the USB hub built into my ASI183 camera. That's actually what it's intended for.
#4 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 30 May 2020 - 11:55 AM
Not a problem, connect away.
Unlike most of the ZWO guide cameras or the ZWO EFWs, the EAF doesn't draw power from the USB connection -- it uses the separate 12V power connection.  So it'll work with any USB connection without worrying about power draw.
#5 Spacedout again
Spacedout again
  • Loc: Indiana
Posted 30 May 2020 - 11:57 AM
Yup
thanks, it makes sense but I didn't want to take a chance on a first light meltdown.
#6 Spacedout again
Spacedout again
  • Loc: Indiana
Posted 30 May 2020 - 12:03 PM
thanks, i was initially under the assumption that it was for guide cam and Efw. Wrong again 😁
#7 Spacedout again
Spacedout again
  • Loc: Indiana
Posted 30 May 2020 - 12:12 PM
Thanks, it's too bad that they can't use the same power source. It's annoying trying to get a good balance on my cem25p with all the cables hanging even when organized. I have a talentcell battery wirh 2 short cables on the way that I can mount on the scope(hopefully) which will leave me with a single flimsy usb cable hanging.
#8 astrohamp
astrohamp
  • Loc: Massachusetts
Posted 30 May 2020 - 12:57 PM
Yes you can.
Have my EAF and an ASI120mm guide camera plugged into my ASI294mc Pro.
#9 OldManSky
OldManSky
Posted 30 May 2020 - 01:06 PM
It is, but the motor just draws too much current to run off of limited USB power.
Cable management is always something to worry about -- you'll get it :)
#10 Stelios
Stelios
  • Loc: West Hills, CA
Posted 30 May 2020 - 04:36 PM
It's for two devices at your pleasure (as long as they don't have a big power draw). I connect the EFW and guide cam, as I don't have an EAF. Works great.
#11 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 31 May 2020 - 09:21 AM
Well, they can use the same (12V) power source for both of course (if it delivers enough current, that is).  I have only one cable running up, and split it close to camera/focuser to power both.
  • OldManSky likes this
#12 OhmEye
OhmEye
Posted 31 May 2020 - 12:10 PM
I use a single 10A 12v power supply to power everything that uses 12v. I also use a cable sleeve so I have a single "umbilical" and tie it down. I really don't like or understand "hanging" cables, there's no reason to let cables dangle and move around, much less be a snagging hazzard. I certainly don't want anything wiggling around blowing in the wind either.
I use split nylon sleeving, I can tuck any cable into it at any point along it's length and don't need to redo the entire thing for every little change. I ziptie it an anchor points so it has the range of motion needed and doesn't dangle where it shouldn't.
TS130 Rig
