Ioptron CEM40 hits tripod leg.
12 replies to this topic
#1 Greg6498
Greg6498
  • Loc: Glasgow, VA
Posted 31 May 2020 - 10:11 AM
Really need help with this issue! My Ioptron CEM40 mount is hitting the leg of my tripod when pointed near the meridian. On my old AVX mount I could adjust the RA and DEC limits, but I don't see any setting for this on the CEM40. I changed the Meridian Treatment setting to meridian flip but I don't remember if that was the default setting or not. Do any of you have an answer on how to fix this problem?
#2 milkychris
milkychris
Posted 31 May 2020 - 11:10 AM
What is your Set Position Limit value?
#3 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 31 May 2020 - 11:20 AM
Is the *mount* hitting the tripod leg, or is the *telescope* ON the mount hitting it?
As milkychris said, check your "Set Position Limit" setting -- in your case, set it to 0.  That tells the mount how far to go beyond the meridian before doing the Meridian Treatment behavior.
#4 eyeoftexas
eyeoftexas
Posted 31 May 2020 - 11:24 AM
If that doesn't solve the problem, or it's the telescope hitting the tripod iOptron makes an extension pier for the CEM40 (https://www.ioptron....duct-p/8031.htm).
  • OldManSky likes this
#5 Greg6498
Greg6498
  • Loc: Glasgow, VA
Posted 31 May 2020 - 11:36 AM
The scope is hitting the tripod leg. It’s touching just enough to stop the tracking.
#6 Greg6498
Greg6498
  • Loc: Glasgow, VA
Posted 31 May 2020 - 11:37 AM
Where do I find that number to check it?
#7 milkychris
milkychris
Posted 31 May 2020 - 12:17 PM
Look at section 5.4.7 in the manual on page 29 https://www.ioptron....EM40_Manual.pdf
#8 stryker66
stryker66
Posted 31 May 2020 - 11:20 PM
I use to have that issue with 140mm refractor so I put more weight since I was still under payload limit, this enable me to push the scope further so it is less overhang
#9 Sasho_Panov
Sasho_Panov
Posted 01 June 2020 - 08:52 AM
I own CEM40EC for almost a year and one (perhaps the only one) thing that is annoying with this mount is the problem you described. I am using it with 115mm refractor.
The only solution in my opinion i iOptron MiniPier extension that I have ordered. From my calculations, it will rise the mount to a afe distance from the tripod legs.
Sasho
Edited by Sasho_Panov, 01 June 2020 - 03:51 PM.
  • otis4411 likes this
#10 johnsoda
johnsoda
  • Loc: SW Ohio, USA
Posted 01 June 2020 - 11:24 AM
I had this problem with long refractors in my CEM60. I got the pier extension, and I’ve never had the problem since.
#11 OldManSky
OldManSky
Posted 01 June 2020 - 08:50 PM
It's a very common problem with all Equatorial mounts on tripods.  Nothing unique about it in regard to iOptron mounts.
And yeah, pier extensions work very well.
#12 Greg6498
Greg6498
  • Loc: Glasgow, VA
Posted 01 June 2020 - 09:49 PM
Sasho
#13 Greg6498
Greg6498
  • Loc: Glasgow, VA
Posted 01 June 2020 - 09:50 PM
I just ordered the mini pier extension today! That should solve it! Thanks!
