Backfocus for WO60mm ED with their latest 0.8x reducer/corrector & the ASI183MM Pro
3 replies to this topic
#1 cheesified
cheesified
  • Loc: Singapore
Posted 31 May 2020 - 10:15 AM
Hi all,
quick backfocus question,
Should the backfocus be 55mm?
On their website it states backfocus should be 56mm for DSLRs but it does not specify for astrocams.
Asking as I am still having difficulty achieving backfocus.
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 31 May 2020 - 11:00 AM
The same, 55mm is where the flat field should be located from some flat surface of the reducer/flattener. Whether you stick a DSLR sensor there or a astro camera sensor is immaterial.
For an astro camera you may need a spacer or two.
A DSLR flange distance is often around 45mm whereas the ZWO's are 6.5mm.
#3 cheesified
cheesified
  • Loc: Singapore
Posted 31 May 2020 - 12:10 PM
At 55mm with the 0.8x reducer, I'm still getting curved stars. On the ordinary 1.0x flattener I'm getting good stars at 55mm though.
Backfocus: 55mm
https://www.cloudyni...405_1886099.jpg
Same goes for 56 & 57mm
Backfocus: 57mm
https://www.cloudyni...405_5756123.jpg
#4 YAOG
YAOG
  • Loc: Southern California
Posted 31 May 2020 - 08:49 PM
Chessified,
You have multiple issues, tilt and spacing are both out. Something is tilting or sagging in the imaging train. The stars are pointing the same direction, this indicates a tilt or tracking problem. Some stars point to the center this indicates a spacing problem. In your case I think the tracking is okay based on the two corners with comatic star shapes pointed to the center.
