NV - Loss of light from 35MM camera lenses and using them afocally?
NV
13 replies to this topic
#1 gatorengineer
gatorengineer
  • Loc: Hellertown, PA
Posted 01 June 2020 - 12:53 PM
Wondering why if a camera lens is designed to cover a 36mmx24MM or a 43MM image circle when used with a NV device at most only a 26mm image circle gets to the NV device, or roughly 77% of the light recieved by the camera lens. Do I have this right?
Second question would it make sense to use a Telescope Eyepiece which could use the full 43MM I would imagine the Aperature stop on say a 50MM russell Plossl, and use the Camera lens afocally?.  There should be enough distance from the flange of the camera lens to the focal plane to accomodate a scope eyepiece....
This seems to obvious what am I missing?
#2 Eddgie
Eddgie
Posted 01 June 2020 - 01:31 PM
No, not quite right. True, the full cone of light does not get to the photo cathode but that does not matter. You can only use 18mm of it (assuming Gen 3 18mm tube).
The center of the 18mm circle  will be fully illuminated. The size of the opening and the speed of the lens determine how big that fully illuminated field will be, but typically the fully illuminated circle will be a minimum of about 10mm for a C mount (and this is the minimum with many lenses providing a far bigger fully illuminated circle).  The PVS-14, ENVIS, and PVS-7 all fully illuminate about 12mm or so of the tube with vignetting outside of that.
Now outside of this circle, the illumination does start to fall off due to vignetting but the fully illuminated circle is called that because inside of this circle, 100% of the light is received.
I don't know what to tell you on the second one.  I don't really understand what you are explaining.
But it does not matter how big the lens is or how big a field is is designed to illuminate. I most cases, you will fully illuminate at least a 10mm to 12mm circle, and if the lens is about f/3 or so, you will pretty much fully illuminate the entire circle.
  • GeezerGazer likes this
#3 gatorengineer
gatorengineer
Posted 01 June 2020 - 02:04 PM
Not saying you wouldnt be fully illuminated, a modern well designed lens lights the corners pretty well with only some loss.  What I am saying is that a camera lens puts the photons it recieves into a 46MM circle, only 18MM worth of that light goes to the NV sensor.
My second point is saying why not go camera lens -> Wide field EP (large field Stop), t-NV device.  This way you are effectively getting every photon.  The NV sensor would get about 6.5x more light than a direct coupled lens The whole 43MM worth of light as opposed to only an 18mm tube.....
#4 Eddgie
Eddgie
Posted 01 June 2020 - 02:51 PM
I am so sorry, but the fully illuminted field gets 100% of the light coming from the objective and everything in that circle is seen at 100% illumination level.
All of the light coming from everywhere in the lens that is headed for that 10mm circle makes it to the 10mm circle.  The center of the field is fully illuminated and is working at the full brightness and resoution of the scope.
Not all of the light headed to parts of the field outside of this circle makes it to that part of the field, but all of the light that is headed from everywhere on the objective makes it into the fully illuminated circle.  Anything in that circle gets 100% brightness.
Now the size of the fully illumined circle is a function of the design and if there are restrictions ahead of the focal plane (as shown in red in this drawing) they will intercept some of the off axis rays and objects or details outside of the fully illuminated circle are indeed shown with reduced brightness.   But not inside the fully illuminated circle.  Every part of this circle sees the entire objective lens.
#5 gatorengineer
gatorengineer
Posted 01 June 2020 - 03:53 PM
Agree 100 percent for C mount.  I am talking an SLR / Dslr lens when used coupled up.  These lenses produce a 43mm image circle.
#6 Eddgie
Eddgie
Posted 01 June 2020 - 07:42 PM
It does not matter.  You only use 18mm of the circle but depending on the speed of the lens, you will get anywhere from about a 10mm fully illuminated circle to an 18mm illuminted circle.
You are not loosing any light at the center of the field.
#7 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 04 June 2020 - 03:25 PM
Eddgie is correct. Put it another way if you don't use the full 43mm image circle of the lens what you lose with a smaller sensor is field of view (FoV), not light. Ignoring vignetting, each point in the 43mm circle receives light from the full aperture. The smaller sensor (in this case the NV device) still benefits from the full aperture.
#8 gatorengineer
gatorengineer
Posted 04 June 2020 - 06:01 PM
I am not saying that the NV Sensor isn't fully illuminated, I am saying that you are wasting alot of photons. That 85mm APs c lens would be better for nv then an SLR lens that optimizes the light into a large frame.
#9 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 04 June 2020 - 09:59 PM
If the fov covers your target you are not wasting photons (from that target). But if your target is larger than the fov yes you are not fully utilizing the fov.
#10 Rickster
Rickster
  • Loc: NC Kansas Bortle 3 SQM 21.8+
Posted 05 June 2020 - 12:05 PM
AJ is right.  Only FOV is wasted.
Keep in mind that the lens projects an image onto the sensor.  The size of the image circle only determines how much of that image can be seen.
#11 gatorengineer
gatorengineer
Posted 05 June 2020 - 12:17 PM
I am not wasting sensor, I am wasting aperature of the camera lens DSLR/SLR.  The light that was collected by the objective is falling outside of the sensor area, is hitting the housing not the sensor.
#12 Mike Lockwood
Mike Lockwood
    Vendor, Lockwood Custom Optics
  • Loc: Usually in my optical shop
Posted 05 June 2020 - 03:29 PM
No.  I think you are misunderstanding something critical about illuminated fields.
Rickster is right - you are wasting sensor, not light.
If a spot is fully illuminated, light from the entire lens/telescope aperture goes to that spot.  This is true for any spot in the fully illuminated field.  A camera lens is designed to illuminate a large field.  You would only notice vignetting at the edge of a very large sensor.
Once you get off-axis, the light is coming in at an angle.  In this case geometry means that light from one edge of the lens is blocked, and that spot is not fully illuminated.  The farther off-axis you get, the lower the illumination gets.
In a Newtonian telescope, the secondary mirror determines the size of the fully illuminated field.  With a prime-focus Newtonian, the size of the corrector will determine the illuminated field.  With a camera lens, it is determined by the design of the lens.
Edited by Mike Lockwood, 05 June 2020 - 03:31 PM.
#13 GeezerGazer
GeezerGazer
  • Loc: Modesto, CA
Posted 05 June 2020 - 11:02 PM
Gator, all of the above responses are correct.
I think I understand what you are saying/asking.  A full frame camera lens produces a 43mm fully-illuminated circle while you only need a fully-illuminated 18mm circle... so why not use an APS-C or even a Micro 4/3 lens instead?  With an equivalent focal length and focal ratio, you would achieve equivalently sensor illumination with a smaller optic.  BUT, if you COULD cram all the light gathered from a full-frame camera lens into a smaller circle, it should be brighter.  And that is actually true.  But it would require a different lens design, making it a faster focal ratio while reducing the size of it's image circle.  The proof of this explanation:  an f:2 full frame 50mm camera lens has a larger aperture (lens) than a 50mm f:2 Micro 4/3 lens... both would fully illuminate the NV sensor, but the Micro 4/3 lens produces a smaller focused image circle.  If the Micro 4/3 lens design had the same diameter aperture as the full-frame 35mm camera lens... it would have a faster focal ratio.
What you suggest is a way to reduce the focal ratio of the full-frame camera lens so that light outside the 18mm NV sensor could be re-directed, rather than washing around the sensor, or being blocked by the C-mount obstruction.  To my knowledge, no optical remedy exists to restructure the light cone from the camera lens objective, without effecting both the FoV (magnification) and the focal ratio.  For example, using a tele-extender (similar to a barlow) on the camera lens will restructure the light cone from the native camera lens.  It also changes the focal ratio by effectively extending the focal length of the camera lens.  The opposite is true for a camera lens tele-compressor... similar to a telescope reducer.  But neither of these devices alters the size of the camera lens image circle.  Camera lenses are designed to provide a specific size image circle... originally to illuminate the film plane.
If I understand your post #1 correctly, you would use the camera lens as a prime objective with light focused into a typical telescope eyepiece with a large enough field lens to accommodate the full 43mm image circle, and have it exit the eyepiece as a smaller diameter image circle... effectively reducing the focal ratio of the camera lens for a brighter image (with correspondingly larger FoV).  Theoretically, it is possible... realistically, you have a challenge to mate different optics that were not designed for each other, to work together compatibly.  But this is essentially what we do when using an NV afocal system... using different eyepieces to achieve different magnifications with corresponding FoV at different focal ratios, which are then used afocally with our NV devices (one optical system looking into another optical system).  But telescopes are designed to focus their light where the focuser resides and have a much bigger range of focus.  Camera lenses are designed to focus their light at one specific focal plane which is usually only 35mm to 54mm from the lens mount, depending on camera brand, and since telescope eyepieces also have different focal planes, you would need a raft of close coupled adapters to make this work with different eyepieces.  Would it be an improvement?  I doubt it.  Too many additional optical surfaces to consider with the potential for increased reflections and field aberrations, like astigmatism or coma.  And, you would not actually be changing the size of the camera lens image circle... it would remain constant.  The image would be brighter because a longer FL eyepiece would be used... just as with a telescope/eyepiece combinations.
Does this make sense?
Finally, we use old 35mm camera lenses mainly because they are readily available and often, very inexpensive.  They allow us to tailor the focal ratio by using their aperture, AND by using them attached directly to our NVD as the prime objective, they can be filtered behind its mount using 1.25" filters in the C-mount adapter.  Used as a prime lens on a NVD without a manual gain control, their aperture ring can be used instead, to control the brightness of the background sky.  Yes, a good portion of the focused image they produce washes around the NV sensor, but the sensor IS fully illuminated.  And to buy a comparable Micro 4/3 lens, to reduce the size of the optic, would cost a lot more $$$.  Old manual, camera lenses remain a cost effective way to achieve short focal length, wide-field images at a fast focal ratio for a bright image.
Ray
Edited by GeezerGazer, 05 June 2020 - 11:43 PM.
#14 gatorengineer
gatorengineer
Posted 06 June 2020 - 06:08 PM
Thanks Geezer that was exactly the point I was trying to make. You stated it much clearer.
It you use say an Apo refractor with a diagonal and an ethos, you are likely going through or hitting at least 10 or so optical surfaces. A camera lens with a Russell plossl is likely a similar count so not sure on the light loss. I have a 3d printer in the mail and as soon as my skills are good enough I will give it a shot with a real adapter. If you look at 19mm vs 46 it should be 4x or so the light even considering the light fall off in most 35mm camera Lens at edge of field.
I have a bunch of extra lens caps and may see if I can rig up a test in the mean time. I have a rokinon 135 f2 that will be my Guinea pig. With a 50mm Russell plossl.
Also tagged with one or more of these keywords: NV
