Fluorite scope lenses costly due to time to grind?
8 replies to this topic
#1 RichA
RichA
  • Loc: Toronto, Canada
Posted 02 June 2020 - 12:47 AM
According to Canon (they use fluorite in more expensive lenses)
"-another challenge since fluorite is so fragile. The engineers at Canon developed a new grinding technique to ensure flawless fluorite lens elements. The downside is that it takes four times longer to grind a fluorite element than a glass element −"
https://cpn.canon-eu...nd_ud_lenses.do
Edited by RichA, 02 June 2020 - 12:48 AM.
  • Rollo likes this
#2 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 02 June 2020 - 03:38 AM
Yes indeed; if anything, they are understating the difficulties. This comes under the heading of ~exotic optical materials~. For example, we made these giant optical prisms for IR spectrometers, to exacting optical standards. The material was single crystal NaCl aka common table salt! Just imagine trying to grind and polish that, without being able to get even a single drop of water, your breath, or even slightly humid air in it, ever! After production, each and every prism assembly is stored in its own dedicated, desiccated, evacuated bell jar, under vacuum... and toted around like that. Breathe on it and you've just destroyed a $10K prism. Accordingly, exotics cost whatever it takes to manufacture and maintain them.
[I worked at B&L back when it was a full-service optical shop. Now they just make contact lenses and bottled water. There is precious little precision production in the USA anymore.]    Tom
  • Alan French, m9x18, daquad and 8 others like this
#3 daquad
daquad
Posted 03 June 2020 - 07:24 PM
So in what instruments was this NaCl prism used if it could not be exposed to air?
Dom Q.
#4 RichA
RichA
Posted 03 June 2020 - 07:38 PM
Interesting.  I'd seen salt crystals used as scintillation detectors in geiger counters, but high optical quality wasn't a criteria.
#5 TOMDEY
TOMDEY
Posted 03 June 2020 - 09:21 PM
Dom Q.
I think it was for laboratory spectrophotometers. They were about three inches on a face, which implies that spectral res was paramount, so they would have had to be tenth wave PV wavefront all the way through! I just saw them sitting in one of the meticulously-maintained cabinets in one of the labs. There was so much optics stuff around that I didn't get a chance to research everything... but sure noticed and pretty much memorized everything I saw. My global mem is deficient... but when it comes to technical stuff, especially optics... I seem to remember everything... and forever!    Tom
The closest ~similarity~ picture I have is this thing I use for objective prism on my 4-inch scope >>>
~click on~ >>>
#6 Alrakis
Alrakis
  • Loc: North Carolina
Posted 05 June 2020 - 08:25 PM
Sounds like the optics for a Nicolet FT-IR spectrometer (Fourier Transform infrared ) or FT-Raman.
#7 Rollo
Rollo
  • Loc: Florida
Posted 05 June 2020 - 08:48 PM
Fluorite is much harder to work with than glass.   It's very delicate and breaks and cracks more easily too.
#8 JohnH
JohnH
  • Loc: Squamish BC Moved!!!!!
Posted 06 June 2020 - 09:41 AM
Fluorite has to be grown, and larger elements take around a YEAR.
Also a very fragile material with excellent cleavage
  • SpaceX likes this
#9 JohnH
JohnH
Posted 06 June 2020 - 09:43 AM
I remember in chemistry class in college we were analyzing little pieces of steel alloy to see how much manganese was in the material. We dissolve the steel and acid and then any specialized instrument we measured the colour of the solution that resulted. Are Professor warned us not to touch the crystal through which the light shine as it would be damaged by humidity of our fingertips. So I imagine it was some material that was transparent in infrared.
