Good Cheap Setup? Or Waste of Time?
accessories astrophotography beginner CMOS equipment imaging
1 reply to this topic
#1 PollAirUs
PollAirUs
  • Loc: Minas Gerais, Brasil
Posted 02 June 2020 - 01:16 PM
Hi folks,
I'm interested in a ZWO lens I saw few days ago, it has a focal length that goes from 2.8mm up to 12mm and it's suitable for meteor capturing.
I'm interested in doing some meteor capture and taking All Sky images tho, but I wonder: If I use this lens at it's maximum focal length with an ASI224 (non-cooled) mounted on a star tracker to take long exposure shots, would it work? I know the images will be kinda noisy, but I hope I can avoid that noise with the stacking, darks, flats and bias.
Another thing to consider is the FOV of the lens, it has a maximum FOV of 100 degrees (when using it at 2.8mm, I suppose), but I'm going to use it at 12mm, so the FOV should be significantly lower. And this simulation in the Stellarium looks good to me, although I can't include the lens FOV in it, I would certainly be satisfied with this field of view in the sensor.
#2 gatsbyiv
gatsbyiv
  • Loc: Doylestown, PA
Posted 02 June 2020 - 01:46 PM
What you're proposing would work, but I'd be concerned about the quality of the lens: chromatic aberration, distortion, etc.  Also, because that camera has 3.8 um pixels, the image scale here won't allow much detail, but perhaps you could try drizzle.  A prime camera lens would almost certainly have better optics if you could adapt it.  But this might be a fun, cheap project.
If you want a start in astrophotography on a small budget, I'd suggest that you'll get better results with a used DSLR and prime lens of 50, 85, or 135 mm.
  • mikefulb, BKMaynard and PollAirUs like this
Also tagged with one or more of these keywords: accessories, astrophotography, beginner, CMOS, equipment, imaging
