Thank you for your help- nexstar aligns properly and is tracking well
5 replies to this topic
#1 Jacksonite22
Jacksonite22
  • Loc: Houston
Posted 02 June 2020 - 11:21 PM
Appreciate the input from the forum - was able to resolve my issues with a factory reset and reentering of appropriate location, time data etc. working like a champ now. Checking out m13 and m5 and hope to see a lot more with less light pollution down here in Houston when it take this scope out to Big Bend.
  • Michael_Swanson likes this
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 03 June 2020 - 02:06 AM
Take the new location data with you when you go OR add Big Bend as a second custom location before.
IF you add Big Bend now then be aware that the scope uses the last location entered.
So if you enter Big Bend now then the scope will use the Big Bend location immediatly, you have to go back and select Houston again.
Have always said these automatic, computerised scopes are amazingly manual in reality.
  • Thomas Marshall likes this
#3 Jeff Lee
Jeff Lee
Posted 03 June 2020 - 07:47 AM
Or add GPS and never worry about location/time:)
#4 Jacksonite22
Jacksonite22
  • Loc: Houston
Posted 03 June 2020 - 11:12 AM
Jeff, I did have my GPS and I don't know if the computer isn't picking it up correctly or not.  Celestron advertises this accessory as plug and play or is there something in the settings to tell it to use the attached GPS?
#5 Terrybythe sea
Terrybythe sea
  • Loc: Gaspe Peninsula
Posted 03 June 2020 - 01:07 PM
Yes, for the SE at least. From the manual:
GPS On/Off - Allows you to turn on\off the GPS module when using the optional CN16 GPS accessory. When aligning the telescope, the NexStar still receives information, such as current time, from the optional GPS accessory. If you want to use the hand control database to find the coordinates of a celestial object for a future date you would need to turn the GPS module off in order to manually enter a date and time other than the present.
Edited by Terrybythe sea, 03 June 2020 - 01:08 PM.
#6 Jacksonite22
Jacksonite22
  • Loc: Houston
Posted 04 June 2020 - 06:27 PM
On my unit it's buried in the utilities menu.  Finally found it and applied it and yes it's much simpler now.  Thanks.
  • Terrybythe sea likes this
