Any disadvantage to Optolong L-Extreme vs L-Enhance?
223 replies to this topic
#76 mewmartigan
mewmartigan
  • Loc: outside of Pittsburgh, PA
Posted 26 August 2020 - 06:07 PM
Slowly raises his hand and asking sheepishly...
So what is the appeal of the L-extreme? Is this mostly for EAA?
I am strictly an OSC guy so the eXtreme works great for cutting out the moon and increasing contrast on certain targets. I don't want to use individual filters with my osc since not having a filter wheel and separate flats is a benefit to me.
  • elmiko likes this
#77 Huangdi
Huangdi
Posted 26 August 2020 - 06:16 PM
I've tried one of these for the last couple of nights through a ASI294MC, and though the results while good, they aren't better than I get with a monochrome ASI1600MM with even my cheap'o Ha and Oiii filters. And integrating monochrome images into color is many times simpler than extracting unwanted colors from a color image.
And the cost of a mini electronic filter wheel with the above-mentioned cheap'o Ha and Oiii filters are about the same price as an Optolong L-extreme filter.
If they were better, monochrome cameras would be pointless.
The point for me is price. Used D3300 with L-Extreme = 500€
ASI1600=1500
FW=300
Filters=700
thats 5x the cost.
  • elmiko and 17.5Dob like this
#78 bosh60
bosh60
    Vendor - SkyTrack
  • Loc: Southwestern Ontario, Canada
Posted 26 August 2020 - 06:30 PM
Brent, nice image! Who did you order the L-xtreme from? I ordered from Agena Astro they are on backorder.
I am from Canada -  https://www.ontariotelescope.com
  • elmiko likes this
#79 elmiko
elmiko
  • Loc: Arizona
Posted 26 August 2020 - 07:32 PM
Thanks Brent.
#80 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 26 August 2020 - 07:50 PM
If your NB setup is so great, why do you have a 294.....
My modded dSLR and L-enhance is $250 less than a 294...not to mention  the cost of mono+ NB filters
  • elmiko likes this
#81 tjay
tjay
  • Loc: just outside of Toronto
Posted 27 August 2020 - 07:45 PM
Darn, they are going to sell out before I can get one now ;)
I'm actually a long way away from buying one, but the images here are amazing!
  • elmiko likes this
#82 Lancelot365
Lancelot365
Posted 29 August 2020 - 05:25 PM
Comparing L-extreme to ZWO Duo-band (similar but supposedly a bit inferior to L-enhance based on the technical reports)
These two images are both 10x300' subs. They are calibrated with the same dark and bias frames,  but obviously different flat frames.
The processing is done by a fully automated Pixinsight script - Denoise, stretch and star reduction.
I used to think they are similar in quality based on my images for NGC7000, but now I think the L-extreme is clearly better.
Guess which is which :)
  • elmiko, acommonsoul and bosh60 like this
#83 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 29 August 2020 - 05:35 PM
Left is L-Extreme and right is ZWO one.
  • elmiko likes this
#84 Huangdi
Huangdi
Posted 29 August 2020 - 06:11 PM
Yes you can see the improved contrast and reduced star size in the L-Extreme image. However this particular nebula (or in general the entire veil complex) is strong in Oiii and that's why it isn't an ideal image in my opinion.
The ideal comparison would be targets especially like NGC7000, gamma cygni, elephants trunk, heart, etc nebulae. While all of those have strong Oiii signal, it's way weaker than  in the veil nebula. Comparing the extracted Oiii channel will really show why I dislike the L-Enhance and why it is no match for the L-Extreme or similar. I've to this date never seen a truly clean Oiii mono image from an L-Enhance filter image and if there is one, it was probably shot with very expensive/fast optics.
#85 Lancelot365
Lancelot365
Posted 29 August 2020 - 09:56 PM
I have not seen clean OIII for NGC7000 or Butterfly nebula with L-extreme by myself...
Your photo inspired me to image on these area with my L-extreme. However I dont have much success with the OIII data right now.
Maybe I need to get more data and longer subs :)
#86 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 29 August 2020 - 10:38 PM
I have some more post processing i need to figure out... some stars with a bit too much red are hard to dial with and others tend to blow out with a mask not quite big enough - learned binarize to help make that better so i'll release another update.
Anxious to try for more nebulas and see what O3 i can get elsewhere
What size telescope did you use to make your images?
#87 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 29 August 2020 - 10:46 PM
This is my best attempt using an AT60ED APO using the L-eNhance filter and my ASI294MC uncooled camera. My subs were 10 min total, gain 450, 8 sec subs.
Edited by Stargazer3236, 29 August 2020 - 10:48 PM.
#88 ImCat
ImCat
Posted 01 September 2020 - 06:59 AM
can anybody confirm I got it right: imaging in the city, Bortle 5-6: I use L-extreme. Imaging in the countryside (Bortle 2-3): I use L-Pro. Is that correct? Camera is ASI 533MC.
  • telfish likes this
#89 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 01 September 2020 - 09:04 PM
What do you image?
#90 ImCat
ImCat
Posted 02 September 2020 - 03:26 AM
What do you image?
Nebulae is what I was thinking about. Let me reframe the question: would using L-Pro instead of L-Extreme make more sense under dark skies?
My scopes are not really suited for the smaller galaxies, but I guess for broadband targets the way to go is always L-Pro, even in the city?
#91 Huangdi
Huangdi
Posted 02 September 2020 - 05:42 AM
It really depends on what targets you are shooting. For emission nebulae where narrowband is usually applied, the L-Extreme will obviously be of great help.
I would absolutely not use a light pollution filter such as the L-Pro at a dark site. In my eyes, it only makes things worse. When shooting from a red zone? Sure. Go for it. But not at a dark site.. It'll likely only mess up your color balance.
#92 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 02 September 2020 - 07:42 AM
L-Pro = light pollution for broadband targets
L-eXtreme = Nebulae for SHO or HOO like targets
Dark site = no filters, if you must use a filter then better L-Extreme for emission nebulae only
  • jdupton, acommonsoul and ImCat like this
#93 sn2006gy
sn2006gy
    Vendor - Rockchuck Summit Observatory
  • Loc: Austin, TX
Posted 02 September 2020 - 10:36 AM
If you're at a dark site and want to shoot with moon up, then the l-pro is good for broadband there too.  The L-enhance/Extreme are viable no matter the skies if you're target is an emission nebula.  You can shoot some in broadband (such as pelican) however most people seem to enjoy the output from filters.
  • ImCat likes this
#94 ImCat
ImCat
Posted 05 September 2020 - 04:49 PM
Ok, color me impressed. Attached is my first image with Optolong L-Extreme, with 97.3% Moon and from Bortle 5/6 area. Keep in mind that I am extremely new to this, took my first DSO picture less than two weeks ago and this is my like third semi-proper image (semi-proper because I did not have any calibration frames for it). This one needs to be reprocessed but for me it is impressive enough.
ngc6888
Edited by ImCat, 05 September 2020 - 04:50 PM.
  • mewmartigan, elmiko, Stargazer3236 and 3 others like this
#95 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 06 September 2020 - 12:34 AM
Exposure details and setting? Camera and Scope?
#96 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 06 September 2020 - 01:18 AM
L-Enhance, night of the full moon a couple of days ago..AT65EDQ, Nikon D5300a
Edited by 17.5Dob, 06 September 2020 - 01:20 AM.
  • elmiko, Stargazer3236, Chunkles and 7 others like this
#97 starbuckin
starbuckin
  • Loc: Massachusetts
Posted 06 September 2020 - 06:58 AM
This guy VisibleDark on YouTube did the same target with both. I have to say, I was impressed enough to order the Lextreme, though I already have and love the Lenhance.
https://www.youtube....YbGUzodg&t=317s
  • elmiko likes this
#98 astrodd
astrodd
  • Loc: NH
Posted 06 September 2020 - 08:46 AM
Here's a 45*300s stack from Friday (Bortle 4) using a ASI533mc/L-eXtreme/RASA 8.
North American Nebula
Edited by astrodd, 06 September 2020 - 08:47 AM.
  • F.Meiresonne, elmiko, Stargazer3236 and 1 other like this
#99 beeboman82
beeboman82
  • Loc: Indianapolis
Posted 06 September 2020 - 09:10 AM
That is a very nice head-to-head comparison.  Thanks for sharing!
  • starbuckin likes this
#100 ImCat
ImCat
Posted 06 September 2020 - 09:24 AM
Exposure: 37 x 180sec. No darks/bias/flats/whatever.
Telescope: Sky-Watcher 150/750mm Newtonian with Baader MPCC V-1 Mark III coma corrector.
Camera: ZWO ASI 533 MC Pro, gain 101, -10°C.
Filter: Optolong L-Extreme 2".
Mount: Sky-Watcher EQ6R-Pro
Guidescope: ZWO 30mm 120F4
Guide camera: ZWO 120MM Mini
Acquisition: ZWO ASIAIR Pro
Date: 2020-09-03/04
Moon: 97.3%
  • elmiko and Stargazer3236 like this
