Flat Frames Over/Under Correcting Back to Back Subframes
6 replies to this topic
#1 SiriusFritz
SiriusFritz
Posted 05 June 2020 - 03:27 PM
Hello,
I've been having some serious issues with flats lately on my RC8. The two attached photos are calibrated subframes that were taken back to back with no focusing in between.
You can see that one has decent correction and the other over corrects. Can this be caused by flexure in the system? I would think if I had that bad of flexure I would have a lot of other problems.
When taking flats on my OrionED80 with the same camera/OAG I don't have this issue.
Thanks for any advice,
Fritz
#2 SiriusFritz
SiriusFritz
Posted 05 June 2020 - 04:26 PM
Alright, something to add to this. If I do not subtract dark frames from the subframes I don't have this issue. Still not great flats, but the exposure to exposure issue is gone.
#3 jdupton
jdupton
  • Loc: Central Texas, USA
Posted 05 June 2020 - 04:40 PM
Fritz,
   The only thing I can think of that might cause this is a change in cooling from frame to frame. If you are running at very high TEC power levels, the control may not be able to keep up.
   Open the FITs Header process in PixInsight and see if your capture software recorded the actual sensor temperature from the camera in the frames. Compare the two you posted to see if there was a thermal change that might have caused a dark current change between exposures.
John
EDIT PS: You may need to go back to the original frames when you look at the FITs Headers. Some PI processes drop some FITs Keywords after operations are complete.
Edited by jdupton, 05 June 2020 - 04:43 PM.
#4 Peregrinatum
Peregrinatum
  • Loc: South Central Valley, Ca
Posted 05 June 2020 - 05:53 PM
What is your calibration process, and what type of camera do you have?
  • kingjamez and RossW like this
#5 SiriusFritz
SiriusFritz
Posted 05 June 2020 - 06:21 PM
Thank you both for the replies.
I checked the FITs header and they are both right at -15C.
My camera is an Atik 383L mono.
When making my master flat I subtract bias only and no dark flats. The bias is taken at the same temperature as the flat, in this case -5C. When it comes to calibrating the final lights, I only use dark frames and the flat frame I just mentioned. I use Pixinsight for all processing.
My flats are shot at 25k in SGP. 3.3 second exposure so safe from the shutter.
Does having my flats at a different temperature than my lights possibly cause this?
Edited by SiriusFritz, 05 June 2020 - 06:26 PM.
#6 Peregrinatum
Peregrinatum
Posted 05 June 2020 - 07:31 PM
Just a little more info... what processes do you use in Pixinsight for calibration, and what settings.
#7 Peregrinatum
Peregrinatum
Posted 06 June 2020 - 10:05 AM
watch these 3 adam block vids and it will answer all your questions:
https://www.youtube....kg441UBNpo&t=2s
https://www.youtube....h?v=SyLERe7ETJY
https://www.youtube....Vx07KIdDMU&t=3s
