Is this a backfocus problem?
9 replies to this topic
#1 Hugo52
Hugo52
Posted 05 June 2020 - 03:34 PM
I have a C11 and focal reduser.
My bacfofus is 146.5 mm, it should be 146.05 +-0.5 mm
I measure it from the latest boint of the FR to the sensor.
Pls look at this picture and advice if the eggs in the corners are caused by a backfocus problem?
Regards Hugo
https://drive.google...iew?usp=sharing
Edited by Hugo52, 05 June 2020 - 03:35 PM.
#2 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 05 June 2020 - 03:44 PM
No. The lower right corner is almost perfect. CCD Insprector shows considerable tilt as well as the need for better collimation.
#3 Hugo52
Hugo52
Posted 06 June 2020 - 08:19 AM
Wilh a level device laser I found 2 rings who are wobbling.
Thank you for analysing.
Regards Hugo
#4 Hugo52
Hugo52
Posted 06 June 2020 - 08:38 AM
Now I see it also with a micrometer that these rings are not good
#5 f430
f430
  • Loc: La Mesa, CA.
Posted 06 June 2020 - 11:36 AM
 For your backfocus measurement, you did measure from the correct location; the flat at the end of the threads.
#6 Hugo52
Hugo52
Posted 06 June 2020 - 03:20 PM
f430, tks
#7 Hugo52
Hugo52
Posted 10 June 2020 - 05:01 PM
Latest update.
With the laser I found out that using a 2 inch filter, Baader or Hutech a tilt causes
I put the focal reducer with all stuff on a stable table and at the end no camera but a big ring.
I put the laser on top of this ring and mark it the spot on the wall a few meters ahead and start turning.
Only using this 2 inch filters I get a swing of 2 cm.
If I do not use a filter, the laser stays exact on this marked spot.
Is this a known problem that filters are causing this problem?
Regards Hugo
#8 Hugo52
Hugo52
Posted 11 June 2020 - 05:02 PM
This wil solve all tthe problems.
https://www.ganymede....is-instelbaar/
https://www.teleskop....nge-15-mm.html
#9 Hugo52
Hugo52
Posted 18 June 2020 - 06:20 AM
Assembled today:
https://www.teleskop...enge-15-mm.html
There is now absolutely no measurable tilt anymore. (Method, see photo)
The back focus is now perfectly set with:
https://www.ganymede...uis-instelbaar/
Now it is time for a clear sky.
Hugo
Edited by Hugo52, 18 June 2020 - 06:23 AM.
#10 Hugo52
Hugo52
Posted 18 June 2020 - 08:34 AM
The problem was reported by Baader, they say that is is not good to use it like I did:
There is no standard for 2" filter threads, so we have designed our filter threads to be compatible with as many manufacturers as possible. A part of this solution is a short filter thread, and in combination with the necessary tolerances, this seems to introduce enough play into the optical path.
A filter cell is usually not designed to be a part of the mechanical adaptation, but only to carry more or less its own weight. To be honest, this is the first time that I've heard of someone integrating a filter cell like this into the adaptation.
