SkyWatcher Eq6-R-Pro Dimension Tripod Legs Closed
7 replies to this topic
#1 missouri_skies
missouri_skies
Posted 05 June 2020 - 03:39 PM
Could someone tell me this dimension of SkyWatcher Eq6-R-Pro Tripod:  Distance from back leg to back leg with the mount leg extensions in the shortest position..  See picture.  It makes a difference to what I'm doing.  I want to see if the tripod will fit on a square concrete pad.
Dan
Edited by missouri_skies, 05 June 2020 - 03:46 PM.
#2 BravoFoxtrot
BravoFoxtrot
  • Loc: Palmer Divide, Colorado
Posted 05 June 2020 - 08:58 PM
~35”
#3 GKA
GKA
  • Loc: South of Norway
Posted 06 June 2020 - 09:16 AM
~35”
Dan
Is this how you measured? i was wondering about the same for a future Upgrade.
  • BravoFoxtrot likes this
#4 missouri_skies
missouri_skies
Posted 06 June 2020 - 11:25 AM
Thanks to you two for taking the time to help me with this.  I appreciate it very much.  Thanks!
#5 GKA
GKA
Posted 06 June 2020 - 05:29 PM
It is BravoFoxtrot that has the answer , i just asked another in your tread , was wondering about the same as you.
  • BravoFoxtrot and missouri_skies like this
#6 BravoFoxtrot
BravoFoxtrot
Posted 06 June 2020 - 08:04 PM
Yep, N to any other point is ~35” with the tripod completely retracted.
I hope this helps.
  • GKA likes this
#7 GKA
GKA
Posted 06 June 2020 - 08:30 PM
Edited by GKA, 06 June 2020 - 08:31 PM.
#8 SimonMiller
SimonMiller
Posted 07 June 2020 - 07:25 AM
I also wanted to put the tripod on a concrete pad. Would it be advisable to put it on a circular (first thought), square, or even a triangular pad? A square pad would be undersized compared to a circular pad, so for a given volume, a circular pad would be shallower?
So, if you started with a “clean slate” (hole in the ground), would you be aiming for a round pad 4” wider than the required diameter - to give the widest support but also to avoid standing on it to minimise vibration transmission? I was aiming for about 5-6” of concrete and/or gravel/sand.
Do you put concrete on the ground (sandy soil), on a layer of sand over gravel? With a membrane?
Simon
Edited by SimonMiller, 07 June 2020 - 07:27 AM.
