Non goto Mount for Orion 120 F8.3
11 replies to this topic
#1 Shane1200
Shane1200
Posted 06 June 2020 - 06:02 PM
I recently purchased a Orion 120 mm F8.3 refractor from a club member.  I have 2 dobs and 102 refractor so I really didn't need another telescope but  I couldn't resist buying it. I  looking for a non-goto mount that would be easy to use with it. This would be a road trip telescope mostly.  What alt-azimuth or eq mount would work with this telescope?  I was thinking about the Celestron cg-4 if I went the eq route.  I have no idea what Alt-azimuth would work with this Orion. The previous owner had upgraded the focuser with GSO crayford so it's heavier than standard Orion 120 F8.3.
#2 John Carlini
John Carlini
  • Loc: Northern Wyoming
Posted 06 June 2020 - 06:08 PM
What is the actual weight and do you plan on doing just visual?
#3 B 26354
B 26354
  • Loc: Southern California semi-desert (NELM mag 5.3)
Posted 06 June 2020 - 06:17 PM
That scope's OTA weighs ~9 pounds, and it originally came on an Orion SkyView Pro EQ mount. I use my C8 (~14 pounds, fully loaded) on the un-motorized version of that mount, for visual only, and it handles it perfectly.
#4 vtornado
vtornado
  • Loc: Northern Illinois
Posted 06 June 2020 - 06:33 PM
I had one of these scopes and  it mounts on a CG4.  The CG4 setup is a little shakey.  Better to go with a CG5 class or Sky view pro.
Unfortunately there is no low cost alt-az mount that will handle it.
  • howardcano likes this
#5 John Carlini
John Carlini
Posted 06 June 2020 - 06:57 PM
I have both the Celestron CG-4 and Orion Skyview Pro EQ mounts.  They are both rated for 20 lbs of visual payload and work well with shorter focal length refractors. A long-tube 120mm f/8.3 could be a bit shaky, even visually. However, if choosing between those two mounts, the Orion has clutch assemblies, making it easier to reposition for different targets...
#6 dusty99
dusty99
Posted 06 June 2020 - 06:59 PM
Yep, CG-4 will be wiggly. I’d go Skyview Pro/Meade LX-70 or more.
#7 Brent Campbell
Brent Campbell
  • Loc: Olympia, WA
Posted 06 June 2020 - 09:07 PM
Look for a used unistar delux (no longer made). Which should handle it easily.
  • vtornado likes this
#8 Jon Isaacs
Posted 07 June 2020 - 04:16 AM
I have a now obsolete StellarVue MG-2 mount.  These are a version of the SkyTee mount.  It handles a 120mm F/8.3 quite nicely.
The difficulty with these scopes is that they are demanding of the mount which means the mount will likely be more costly than the scope.
#9 Hesiod
Hesiod
Posted 07 June 2020 - 04:50 AM
I would use a T-sky/SkyTee (or the maybe Twilight 2) if prefer alt/az; as for eq mounts, an eq5 should do nice, as could any from the Great Polaris series
#10 howardcano
howardcano
  • Loc: Olathe, KS
Posted 07 June 2020 - 03:04 PM
I had the Orion 120 f/8.3 on the Skyview Pro.  The combo was far too shaky for me, even in those moments when the wind dies down (which doesn't happen often here).
I sold the scope and kept the mount for use with other telescopes, though I did have to replace the faulty dual-drive electronics with my own.
Edited by howardcano, 07 June 2020 - 03:06 PM.
#11 vtornado
vtornado
Posted 07 June 2020 - 04:52 PM
unistar macro-star will handle the scope.  I have one but did not mention it because it is no longer in production.
#12 dusty99
dusty99
Posted 07 June 2020 - 07:34 PM
Who is selling unitstar now?
Edited by dusty99, 07 June 2020 - 07:34 PM.
