iOptron CEM60 on the Tri-Pier 360 - Center Bolt Issue
6 replies to this topic
#1 Dodde
Dodde
  • Loc: Sweden
Posted 07 June 2020 - 02:21 AM
iOptron claims the CEM60 center bolt fits the top plate of the Tri-Pier 360. To me it looks like the center bolt hole is much shallower on the 360 top plate than on the original tri-pier top plate and that the center post/bolt is manufactured to fit a deeper recessed mounting hole than the Tri-Pier 360 top plate provides. Is this an oversight on iOptrons behalf or does it actually properly work?
Please see the included image for reference.
I have no frickin clue why I cant link a simple jpg from imagebin to here so here you go ... https://imagebin.ca/v/5PBNPp2oDxI8
#2 Hilbily
Hilbily
  • Loc: VA
Posted 08 June 2020 - 01:39 AM
Looks to me that the top plate is not the right one for the CEM60.
Maybe there is a different plate/adapter that you are missing.
Looks totally different to what is on the US Ioptron site:
https://www.ioptron....duct-p/8037.htm
Edited by Hilbily, 08 June 2020 - 01:41 AM.
#3 Dodde
Dodde
  • Loc: Sweden
Posted 11 June 2020 - 02:16 PM
The mount wont rest properly on the top plate as the flange of the centerbolt keeps it wiggling around half a centimeter above it. I have not seen any other top plate or center shim sold by iOptron to allow accomodation of the CEM60 on the Tri-Pier 360.
Illustrated in the linked image below is the center post mounted to the round center shim of the Tri-Pier 360 top plate. As clearly seen, it wont recess properly.
https://imagebin.ca/v/5Pgu08OA5MkM
#4 Hilbily
Hilbily
  • Loc: VA
Posted 11 June 2020 - 07:58 PM
One of the two pieces is not made to specification or it is an engineering/drafting/QC mistake.
5-10 minutes in a lathe to open up and deepen the counter bore in the round plate and/or trim off the threaded side of the brass piviot.
Whoever you bought it from should send you the correct parts or pay for the lathe time to fix it.
#5 Dodde
Dodde
  • Loc: Sweden
Posted 13 June 2020 - 01:37 AM
Ben exchanging a few emails with iOptron support and all I can say it s total confusion on their behalf. Support isvaguely suggesting there is a second revision of the Tri-Pier 360 top plate that they not yet have access to so they cant confirm either way which center post/stud/bolt works on the mount togehter with the CEM60.
#6 Dodde
Dodde
  • Loc: Sweden
Posted 21 June 2020 - 02:47 AM
Still no proper resolution offerd by iOptron support. After telling me to put a drill to the top plate or purchase a non existing "center stud with screw" in their webstore, they have stopped responding.
Edited by Dodde, 21 June 2020 - 02:48 AM.
#7 Xeroid
Xeroid
  • Loc: USA
Posted 21 June 2020 - 10:27 AM
Time to move on....
How about returning the 360 pier and getting a Tri-Pier? Lower cost, holds 100kg, less grief and hassle.
Then write a letter to iOptron telling them their support needs a "refresh"...lol.gif
Edited by Xeroid, 21 June 2020 - 10:29 AM.
