Hi all,
Ok, finally, I'm going to write up some observations of things other than double stars and random star fields
Eyepieces present are: Leica HC PLAN s 10x/25; Zeiss S-PL 10x/20; Zeiss PL 10x/18 with 24.5mm field stop; Nikon CFUWN 10x/25; Meade 26mm Super Plössl; Brandon 24mm Questar version.
Fair warning: if you're a Brandon fan, you might not like some of these outcomes. I'm just reporting what I saw!
Testing for deep sky contrast and throughput
First target is M27, in A-P 130 GTX at f/15 at 78x. Keep in mind this is in a white zone, middle of cambridge massachusetts.
Group 1: Leica 10x/25 and Zeiss S-PL. Not to much surprise here is there? Both of these eyepieces show the distinct rectangular shape (no "apple core" from these skies), with one end of the rectangular noticeably brighter. Both shows a bit more nebulosity in averted vision, but somehow the S-PL seems to show just a little more. I'm tired of the Zeiss being in Group 1 all by itself all the time though, so I'm calling this a near-draw
Group 2: Nikon CFUWN, Zeiss PL 10x/18, and Meade Super Plössl were great as well- the nebulosity can be seem as a rectangular patch, but it's just a bit harder to hold in direct vision compared to the Group 1 eyepieces.
Group 3: Sorry Brandon fans... The Brandon brings up the rear here. It just seems to have less light throughput. It was the hardest to hold M27 in view.
Second test is M13, same telescope and power as above.
Group 1: Same as above, except the Zeiss 10x/18 joins the S-PL and the Leica HC PLAN s 10x/25. These eyepieces can see a vast amount of structure, with a full blanketing of tiny stars over the large area, even a fair distance from the "glowy part" of the cluster.
Group 2: Meade and Nikon. The Meade did surprisingly well and can barely be told apart from the premium makes. I was pleasantly surprised, but overall, just a bit less "sandy" of a texture on M13. If I weren't comparing these side by side with the Zeiss and Leicas, I wouldn't think twice.
Group 3: Again, the Brandon seems to have real issues with light throughput, even though it's clean and the single coatings don't have any problems. It noticeably shows fewer stars compared to the others.
Third test is M11, same scope and mag
Group 1: The S-PL and Leica were by themselves in the top bracket again, with impossibly sharp stars that snap to focus. Even prodding the fine focus on the A-P changed the view significantly. A truly marvelous sight! Very rich star field despite the light pollution, especially in the northern part with a lot of texture.
Group 2: The Meade is also beautiful and shows a thick veil of resolved stars. However, the texture in the unresolved stars in the cluster itself is not quite as obvious as in the Zeiss and Leica. I didn't look through the Zeiss 10x/18 or the Nikon for M11.
Group 3: The Brandon sees a lot of the sharp stars in the cluster, just like the S-PL and Leica. Very pleasing. But the view is missing a veil of dimmer star over a larger area, so overall I prefer the Meade, even though the slightly cleaners stars in the Brandon has its appeal.
Note on edge sharpness
As I noted in earlier tests, the Zeiss S-PL is perfect at the edges while all the others show some degradation. I'm pretty picky about edge sharpness, but I have to say, even at f/8.2, the Leica and Zeiss 10x/18 and the Nikon did not bother me. As long as a very bright star is not at the field stop, there's nothing in the field to remind me of the imperfections, although having a mag 3 or higher star in the outermost FOV does result in some visible messiness around the star. Not intrusive though.
So overall, for deep-sky, my ranking would be pretty clear:
1: Leica and Zeiss S-PL: The S-PL is slightly better, and the 10x/18 is slightly worse than the Leica. But with wider fields of the Leica makes up for the tiny different in performance and join the S-PL here. If I picked one, it would probably be the Leica.
2: Nikon and Zeiss 10x/18: The Zeiss is slightly better than the Nikon in edge correction and maybe in that last bit of sharpness and contrast. The Nikon in turn is slightly better than the Meade, with slightly tighter stars and a slightly bigger AFOV. But they're all close and pleasing. Compared to the Zeiss S-PL and Leica, these two eyepieces seems a little less able to pull out the really borderline stars and subtle contrasts in surface brightness, but it's a really really small effect and I'm not even 100% sure it's real. Just pretty sure...
3: Meade: I was pleasantly surprised how small the gap is between this humble stand-by and the really premium brands.
4. Brandon. Super sharp and beautiful star rendition, but just too dark! I would say the difference between groups 1 and 2 is small, but the gap between between the Brandon and the others in transmission is quite noticeable.
Roger
Edited by elstargazer12, 17 June 2020 - 04:46 PM.
