Sky-Watcher ESPRIT 120ED Super APO
refractor
87 replies to this topic
#51 telfish
telfish
    3D Astro Solutions, custom 3D printing for Astrophotography
  • Loc: Adirondack Mountains NY
Posted 10 September 2020 - 09:01 PM
I kept the one that came with the scope. It's fine. Try it and change it later if you feel it's not working for you. No need for a long plate as you can move the scope in the rings for balancing and a longer plate can allow more twist.
#52 mikela
mikela
  • Loc: Los Angeles
Posted 13 September 2020 - 01:16 PM
I currently have a CGX-L mount for my EdgeHD 14.  Would I be able to use this for the 120ED?
#53 thesubwaypusher
thesubwaypusher
  • Loc: New York City
Posted 14 September 2020 - 06:07 PM
#54 thesubwaypusher
thesubwaypusher
Posted 14 September 2020 - 06:23 PM
I have this problem with my Esprit 150.
I can't understand why there aren't three screws, if there were three then it would be possible to hold the extended dew shield in a straight position.
john
Hi John:
I have the 150 and have never had a problem with the shield. But I can imagine that you guys are not pushing it up hard enough. Push it HARD to its fully extended position and HOLD IT and tighten the two screws. Don't allow it to start falling back down before tightening, or it will droop, causing the issue you have.
Good luck!
  • agavephoto and janapier like this
#55 John Turley
John Turley
  • Loc: Sheffield, England
Posted 15 September 2020 - 09:45 AM
Hi John:
Good luck!
Thanks for the tip, I tried it, but it didn't seem the make much difference with my scope, it tends to droop when you fit the lens cap.
John
Edited by John Turley, 15 September 2020 - 09:47 AM.
  • thesubwaypusher, Live_Steam_Mad and Barry A. Waters like this
#56 Barry A. Waters
Barry A. Waters
  • Loc: North Florida Panhandle / South Georgia US
Posted 17 September 2020 - 01:33 PM
Yet another question: I will most likely get a dedicated imager (CCD / CMOS) at some point in 2021 but for now a couple of APS-C Nikons (D5100/D7100) will have to do. I mounted them to the tube via the instructions in the manual and found that they both only achieved focus at the very end of the focuser's maximum extension. It looks like I need an extension between the  focuser tube and the flattener to give me some play on either side of focus. Does this sound right (normal)?
Barry
#57 telfish
telfish
Posted 17 September 2020 - 01:41 PM
Barry
With my ZWO cameras I am at around 7 on the scale on the drawtube.
  • Barry A. Waters likes this
#58 Barry A. Waters
Barry A. Waters
Posted 19 September 2020 - 06:51 PM
I could work with that BUT I may not have as bad of a situation as I thought. I talked with the vendor (Woodland Hills C&T in my case), explained the issue and told them what I was focusing on. I haven't been able to get the scope outdoors so I'm looking out a window of my home. I'm in a pretty flat area so my best 'local' daytime targets are the tops of distant pine trees no more than 175+/- Yards away.
As their Tech explained to me, the Focus Point is the Focus Point BUT there can be quite a difference between focus at Infinity (as you would have with objects in the heavens) and things much, MUCH closer (my pine tree tops). I can say that in 'observation mode' (star diagonal & a 2" 40mm Plossl eyepiece) I was achieving focus on the pine tree tops at just past half travel on the focuser. The length added to the light path in that combination was a help apparently.
So I will wait until I can test 'outside & up' before I become further concerned. I CAN say that in 'observation mode' the Sky-Watcher 120mm Esprit makes for one HELL of a 'Distant Pine Tree Top Looker'... :-)
Barry
#59 Barry A. Waters
Barry A. Waters
Posted 19 September 2020 - 07:15 PM
Flattener only, e.g. ~1.0x.
I assume the ring holes are the normal 1/4"-20 (they are on my Esprit 100 rings).
Yes - The Sky-Watcher supplied piece is a Flattener ONLY (no FL change) and 1/4"-20 is correct for the ring's attachment bolt threads. Thanks! I just got 4 at the local ACE and they all threaded right in as smoothly as you could ask for.
I got a response from Sky-Watcher on the other (smaller) drilled & tapped holes on the green anodized mounting plate and was told that those are M6 so I should be good now on adding a handle (1/4"-20 bolts) and some front/rear Anti-Launch blocks (M6). Thanks!
Barry
#60 Bcteleskier
Bcteleskier
  • Loc: Colorado
Posted 20 September 2020 - 04:21 PM
Barry
Barry,  check your back focus distance.   It should be 75mm from the camera facing face of the included flattener.   Google for the “Esprit 120 manual” and see the picture on page 8 of the pdf.  I believe the printed manual may have shown it incorrectly.   At 75mm back focus distance my focuser is at the 55mm mark.
Ralph
Edited by Bcteleskier, 20 September 2020 - 04:22 PM.
#61 Barry A. Waters
Barry A. Waters
Posted 23 September 2020 - 08:20 PM
Ralph
From what the manual says (I only have the online .PDF as there was no printed manual in the OTA box?!?) I appear to have everything assembled as it should be. From what I can see there really is no other way to assemble things due to the progressively smaller thread diameters of the components toward the DSLR end. The required 75mm distance between the Field Flattener's back face and the Focal Plane of the Nikon's Sensor (as marked on the D7100 Body) also measures out correctly.
Manual and equipment wise I have what the first attached image below shows (with the two-piece 3a-3b extender tube in my case). The second image shows the Nikon D7100 I have attached to the assembly. I'm thinking I still need a wee bit of an extension (1 1/2" to 2"?) in-between the focuser and the supplied Field Flattener.
I'm now at the point where I'm having questions that concern Auto-Guiding equipment selection, Dedicated Image Camera selection (Color vs Mono & CCD vs CMOS), Filter Wheel needs and Software requirements. For now I'm going to to spend a while (well into the Spring of 2021) with just using Mount Tracking (EQ6-R Pro) & the D7100 body for getting acquainted with things but want to get a start on the other stuff as soon as I can.
All of that (Auto-Guiding, Dedicated Imagers, Filter Wheels, Software etc.) sounds like they may be questions best asked in other areas of the site. Any direction of where I should ask them (Forum Title?) would be very much appreciated!
Barry
Edited by Barry A. Waters, 23 September 2020 - 08:33 PM.
  • Live_Steam_Mad likes this
#62 cyendrey
cyendrey
Posted 24 September 2020 - 03:31 PM
I have a Esprit 120 on order and expecting delivery next month smile.gif A few questions...
1) The Losmandy plate that ships with it - are recent copies coming with the black or green plate? I have seen images on the web of both but not sure what the latest ones ship with (or if there's even a difference aside from colour?) I found the specs for the green one, but not the black one.
2) Is the stock plate that comes with it 'fit for purpose' or should it be replaced?
3) I assume I would have no trouble mounting a Vixen-type bar to the top of the rings (onto which other accessories will be mounted, eg guide scope?)
4) Can anyone confirm the appropriate size dew strap for this scope?
As a recent purchaser of an Esprit 100ED, I can tell you that the supplied (green) Losmandy D plate with the SW Esprit is for show only.  Amazon, ADM, HighPoint, Opt all can provide a longer D plate (I have an 11" on the bottom and a 14" on the top).  The reason you need the longer D plate is to allow movement to balance the rig in the DEC axis.  The supplied OEM D plate is barely long enough to fit the the saddle of the Skywatcher tripod and provide no range of motion for balance.  So, IMO< it has a cosmetic purpose, but functionally, it is almost useless.
I don't agree with the idea of loosening the rings and moving the scope in the rings for balance.  At least on the Esprit 100, the range of movement in the rings is very limited, only about 1/2" in either direction.  The DEC balance point with the FF, extensions, camera, focuser, Guide scope/guide camera will be well outside the limits imposed by the short OEM plate.  As I look at mine (now on an Ioptron GEM45), the center of the rear ring is just below the center of the saddle. which means that only the front ring would be in the clamp on the mount with the OEM D plate.  On the SW EQ6R, because of the way the clamp plate is shaped on the saddle, the rear portion would also be unsupported/clamped.  Thus the need for the longer D plate.  I don't have a field rotator or filter wheel, or OAG, all of which would tend to move the DEC cg further aft than it is currently.
Edited by cyendrey, 24 September 2020 - 03:42 PM.
  • Live_Steam_Mad and Barry A. Waters like this
#63 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 24 September 2020 - 05:56 PM
Esprit 100 5" dovetail works fine for me with my G11, BUT the G11 has a MUCH larger saddle (~8") than most mounts.  Smaller saddles could need longer dovetails.
#64 Barry A. Waters
Barry A. Waters
Posted 30 September 2020 - 08:42 PM
Finally we are getting some clear and cooler weather in my neck of the woods and it motivated me to get the OTA Handle cut because it looks like I'm about to get the rig out for some Visual Observing and maybe a few DSLR shots of the Moon this weekend. Baby-Steps all but I'm looking forward to it! :-)
I made the Handle (very simple but STRONG) out of some 1/2" OD Square Section Mild Steel Tubing I found at the local ACE Hardware. The walls are 3/64" thick and all it took was a couple of angled cuts with a hand-held hacksaw (w/new blade!), a bit of filing to dress things up and drilling two accurate holes (one on each end) for the 1/4"-20 Allen Head bolts used to attach it to the Scopes Rings. I was originally looking at just using 'strap' steel but the Square stuff just felt so good in my hands and with it there is NO chance of 'flexing'!
The real issue was how long to make the Handle. The green anodized Mounting Plate supplied with my Scope is about 11 & 1/2" in length and while the Plate has several optional holes drilled for repositioning the Rings it comes stock with both Rings attached to the outermost positions on each end of the Plate.
Balancing of the OTA w/attachments, however, could dictate another arrangement so I looked into that first and it appears that the stock positioning appears to be pretty serviceable, especially when the Plate is used with the Sky-Watcher EQ6-R Pro Mount, which is what I have and has a pretty decent 'saddle' at about 5 & 3/4" in length.
I've tested the OTA balance in Visual Observation Mode (Star Diagonal & Eyepieces) and in DSLR Mode w/the Field Flattener (supplied) & DSLR attached and I have PLENTY of room for adjustment with the Rings in the stock position for both modes. So far so good but what about a full AP Imaging Train with a Focusing Motor, Field Flattener, Motorized Filter Wheel and a Dedicated CCD or CMOS Camera w/Cooler?
From what I can see, the stock Ring/Plate positioning looks fine in that configuration too. I don't have any of that equipment yet and cannot say definitively BUT I've seen several pretty tricked-out rigs on the web that are using it just fine. See the screen-shot below from one of John Robertson's Deep Sky Channel videos (Great Stuff by the way!). He has the OTA and all of his stuff on the EQ6-R Pro Mount. He's got a LOT of stuff there (IMHO) and seems to be doing just fine with the stock Ring/Plate setup.
SO, I chose to make the Handle to fit that stock setup (see photos below) and feel it may very well be the only Handle I need to make. If I need another (shorter) version it will be easy enough to make and I can deal with that. I CAN say that the 1/2" Square Tubing is STRONG and that I have NO worries regarding hefting the scope with it. Then, of course, comes painting the thing but that should be easy. I also cut a couple of 3" long 'anti-launch' blocks today from the same stock for attachment to the underneath of the Mounting Plate. I have nightmares about "Honey, why is the telescope slowly sliding off the... OH NO!!!" :-)
Barry
Edited by Barry A. Waters, 30 September 2020 - 09:17 PM.
#65 njrusty
njrusty
Posted 05 October 2020 - 02:11 PM
Barry, your top picture shows an second dovetail attached to your SW??  Did that come with your scope?  I have a SW120 on order and hoping to use an OAG but worse case I have a Celestron 80mm I was going to use as a guider and will need to attach on top of the SW.  What size screws would fit the holes on top of the ring assembly????  Thanks!
#66 telfish
telfish
Posted 05 October 2020 - 02:39 PM
No top dovetail ships, 1/4 20 is the screw.
#67 Barry A. Waters
Barry A. Waters
Posted 08 October 2020 - 02:15 PM
That's John Robertson's rig and in his YouTube video he says it's an add-on that was purchased separately from Sky-Watcher. All of the tapped holes in the supplied rings are 1/4"-20. On the subject of the threaded holes on the mounting plate that DOES ship with the scope, it appears that I got some incorrect info from SW so I took the plate to ACE today and discovered that it has THREE different size holes tapped! The attached image shows them circled. Hope this helps.
As an aside, in removing the scope from the EQ6-R to detach the mounting plate I got to actually USE my new handle for the first time and it made things SO much easier AND safer to have a secure, two-handed grip on the OTA! :-)
Barry
Edited by Barry A. Waters, 08 October 2020 - 02:22 PM.
#68 njrusty
njrusty
Posted 10 October 2020 - 06:08 PM
Awesome Barry.  Thank you!!!
#69 khursh
khursh
Posted 10 October 2020 - 06:31 PM
Some recent work with mine:
California Nebula NGC 1499
get.jpg?insecure
PacMan NGC 281
get.jpg?insecure
  • alphatripleplus and Barry A. Waters like this
#70 drd715
drd715
  • Loc: Fort Lauderdale
Posted 10 October 2020 - 07:04 PM
I feel that basic geometry will tell you that Apex never had a chance to cover full-frame. -- The Apex L should work fine at APS-C (28.3mm diagonal) and smaller sensors, but not full-frame.
I have no idea why Starizona made the output so small, though larger output would probably need larger diameter (higher $$) lenses as well.
The comments I got from Starizona about the Apex diameter indicate that the design was meant to fit inside of a 2" draw tube - thus limiting the diameter of the optics. The thought was there are a lot more 2 inch focusers than 2.5+ inch focusers in use. I am hopeful that they will produce a 2.5 or larger bodied vesion as i believe that the 2 inch version will still cause problems at aps-c depending upon focal ratio. It seems like a very desirable reducer but it really needs to have a large body version for big sensors.
Sent from my SM-N950U using Tapatalk
#71 skyward_eyes
skyward_eyes
    Vendor - Sky-Watcher USA
Posted 10 October 2020 - 11:44 PM
We have a 0.77x reducer coming after the new year which handles full frame sensors. We released the information on our webcast last Friday on our YouTube channel.
  • agavephoto and SilverLitz like this
#72 njrusty
njrusty
Posted 11 October 2020 - 10:08 AM
Have an SW120ED on order now.  Would have waited to after new year regarding the reducer.  Should I cancel order and wait until next year to purchase to get the reducer????
Edited by njrusty, 11 October 2020 - 10:14 AM.
#73 skyward_eyes
skyward_eyes
Posted 11 October 2020 - 12:51 PM
Do you have an Esprit 120 on order or an Evostar?
#74 njrusty
njrusty
Posted 11 October 2020 - 02:04 PM
Esprit 120 on order.  Believe it will ship to me end of Oct was last update few weeks ago.
#75 skyward_eyes
skyward_eyes
Posted 11 October 2020 - 02:49 PM
Not sure why you would cancel the order and wait. The reducer is optional and can be added anytime. If you have an Esprit on order it’s best to wait it out for your scope. Canceling and reordering just out you further down the list.
Edited by skyward_eyes, 11 October 2020 - 02:49 PM.
Also tagged with one or more of these keywords: refractor
