Fixing a Swift RA clutch
8 replies to this topic
#1 GoldSpider
GoldSpider
  • Loc: Pennsylvania
Posted 25 June 2020 - 03:00 PM
I'm working on getting the RA clutch on my Swift 831's mount to properly apply and release friction to the RA shaft.  When I opened it up, there was what appeared to be a poorly fashioned strip of aluminum between the clutch bolt and the shaft.  Before I go too far down a rabbit hole with this, what is the "correct" material that should go between the bolt and shaft?
Here's what's in mine:
Ra clutch1
Ra clutch2
Thanks for the advice.
#2 Couder
Couder
  • Loc: Missouri Ozarks
Posted 25 June 2020 - 03:34 PM
So is the aluminum acting as the brake? If so, maybe brass? Or possibly Teflon? I have some thin brass and Teflon if that's the way you want to go.
#3 GoldSpider
GoldSpider
  • Loc: Pennsylvania
Posted 25 June 2020 - 03:44 PM
That's the word I was looking for.  Yes, that raggedy piece of aluminum is acting as the brake.
#4 Kasmos
Kasmos
  • Loc: So Cal
Posted 25 June 2020 - 04:07 PM
While it's sort of a brake, it's probably also serves as a buffer so that the hard steel of the screw doesn't mare the shaft it press on.
It could be original. Hopefully a 831 owner will chime in soon
#5 CharlieB
CharlieB
  • Loc: Southern NH
Posted 25 June 2020 - 04:13 PM
Brass.
#6 CharlieB
CharlieB
  • Loc: Southern NH
Posted 25 June 2020 - 04:18 PM
You can see it in this photo on top of the shaft.
  • GoldSpider and Kasmos like this
#7 GoldSpider
GoldSpider
  • Loc: Pennsylvania
Posted 25 June 2020 - 04:21 PM
Charlie I figured you'd have a picture of exactly what I was looking for!  I might as well do some cleaning and re-greasing while I'm in here...
#8 CharlieB
CharlieB
  • Loc: Southern NH
Posted 25 June 2020 - 04:27 PM
If you need exact dimensions, let me know.
#9 GoldSpider
GoldSpider
  • Loc: Pennsylvania
Posted 25 June 2020 - 05:25 PM
If you don't mind.  If I can't get this aluminum piece into a shape that works (appears to be too thick) then I'll ask my machinist friend to make me one out of brass.
