Mounting a wedge on a Celestron tripod
15 replies to this topic
#1 ANM
ANM
  • Loc: El Paso, Texas, USA, Earth, Sol system, Orion-Cygnus arm, Milkyway
Posted 29 June 2020 - 04:36 PM
I'm getting the components together to have a C90 Astro equatorially mounted on a Celestron wedge and tripod. I have the Celestron tripod and a wedge, but I'm not sure if the wedge is Celestron or not though it fits the tripod. The bolt holes in the wedge are slotted to facilitate polar alignment. There is a threaded hole in the center of the wedge that looks to be 3/8" NF — it looks like there should be a bolt/pin threaded into that hole but with the end of the bolt turned down to a "pin" with a smooth diameter of about 1/4". I think the 1/4" "pin" goes into the unthreaded center hole in the top of the tripod.
This is the tripod and wedge:
Here's a closeup of the center hole:
Anyone know what the center bolt/pin/whatever is supposed to look like?
  • Terra Nova likes this
#2 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted 29 June 2020 - 04:46 PM
You’re good with the three. Good question though, as I don’t know why there’s a middle. We’ll find out soon I’m sure! I hope you enjoy your C90 Astro! A rare bird!
  • ANM and Augustus like this
#3 Kasmos
Kasmos
  • Loc: So Cal
Posted 29 June 2020 - 05:35 PM
That wedge is for the C8 and diecast large base C5. It's not designed for a C90 as it's tilt plate base is too large.
It might work with new holes drilled.
Here's a C90 wedge
Noted by the big slot in tilt base
BTW, not sure what the center hole is for,  never used it.
Edited by Kasmos, 29 June 2020 - 05:40 PM.
#4 ANM
ANM
Posted 29 June 2020 - 06:16 PM
Here's a C90 wedge
Yes but I have an adapter plate to go from C90 to C8 so I'll be okay. I wanted the C8 wedge since I also want to find an early C8 or C5 — I haven't decided which yet.
#5 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 29 June 2020 - 07:22 PM
Celestron tripods never came with any center pin I’ve seen although the tripod and wedges had the hole.
Dave
  • Don W and ANM like this
#6 ANM
ANM
Posted 29 June 2020 - 08:12 PM
Maybe the hole was to attach to a different style tripod? Something with the threaded center bolt like many tripods use...
The C90 with the adapter plate between it and the wedge:
  • davidmcgo and deepwoods1 like this
#7 Don W
Don W
    Founding Member
  • Loc: Wisconsin, USA
Posted 29 June 2020 - 08:47 PM
David is correct. Older Celestron wedges do not have  a threaded center hole. Meades do.
#8 Kasmos
Kasmos
  • Loc: So Cal
Posted 29 June 2020 - 10:17 PM
After I logged off I thought of those adaptor plates. I'm guessing it's the ones on ebay.
#9 ANM
ANM
Posted 30 June 2020 - 10:15 AM
Yes that's where I got it, and I also bought the wedge from him. I think he has one of the adapters left. It is a very nicely machined and finished part.
#10 Kasmos
Kasmos
  • Loc: So Cal
Posted 30 June 2020 - 02:58 PM
It's a good solution if you have several models and don't want to store the extra gear.
#11 ANM
ANM
Posted Yesterday, 10:32 AM
As I was doing this I realized that the OTA can be reversed in the saddle.
Here's the (almost) finished project:
With the saddle reversed everything clears the Astro mount
#12 ANM
ANM
Posted Yesterday, 10:37 AM
Does that make this a Meade wedge then? I just kinda assumed since it fit the tripod it must be a Celestron...
Edited by ANM, Yesterday, 11:26 AM.
#13 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted Yesterday, 11:57 AM
My Celestrons have the hole. The only Meade I have has a larger hole.
#14 ANM
ANM
Posted Yesterday, 01:39 PM
My wedge has a central hole that is threaded 3/8"-16tpi National Coarse. Is your Celestron wedge drilled and threaded? The tripod has an unthreaded hole that is aligned with the hole in the wedge but is smaller, .283 inch.
P.S.: I sent it too early. The .283 inch drilled hole in the center of the tripod is for a 1/4"-20tpi bolt to attach the C90 Astro mount to the tripod. The bolt goes through the hole from below and into the center axis of the Astro mount — the C90s usually have a red sticky dot covering the hole.
Edited by ANM, Yesterday, 01:52 PM.
#15 houndsbourgh
houndsbourgh
  • Loc: Hailey, Idaho
Posted Yesterday, 07:19 PM
Sounds like you pretty much have it figured out. The center hole on the tripod is to mount the C90 Astro in a alt-az configuration. The center 3/8" hole as far as I remember (early 80s) is to mount the wedge on a surveyors tripod. I have also seen many home made accessories use it through the years. Here's mine with a eyepiece holder.
Edited by houndsbourgh, Yesterday, 07:25 PM.
  • ANM and Kasmos like this
#16 ANM
ANM
Posted Yesterday, 08:23 PM
The eyepiece holder is a cool idea!
