You guys are leaving a trail of frustration recommending the DSI method. If a person has a GSO scope collimating that way is virtually impossible because of the primary mirror mechanics. Also even most high end manufacturers where that method works well recommend against that method (Aluna, the original RCOS, Officina, DFM, etc...) are all in that camp. Personally I believe it has its place and I use it to finish the secondary BUT it should not be the first choice.
Touché, point taken...
I did not have time to the write down the necessary essay yesterday, so my short reply was quite inadequate. That is because "It depends..."
Let's suppose someone has bought his 1st RCT scope from some astronomy shop (probably GSO/AT/whatever-branded Chinese RCT). That device is quite well collimated as it left from factory, because these scopes tend to keep collimation fixed where ever that's adjusted. Here's my 10" GSO RCT scope's first light image without any reducer etc. As you can see it has almost perfect star field without any major flaws.
Then the little devil on your shoulder starts to whisper about lower left corner's slightly oblong star shapes.
Or maybe the free evaluating version of CCD Inspector software gives you something "less-than-perfect" test results for the same star field.
At that stage every fresh RCT scope owner should really stop there and think.
Also reading more basic information from RCT collimation from these forum messages (RCT collimation difficulties actually) would be highly advisable. All this before any new RCT owner makes any adjustment to his RCT collimation. This new RCT owner might even have some old collimation tools in his possession due to his previous scope history. Maybe one beam laser collimator, which he eagerly tries on the new scope's focuser.
He thinks "Well I have collimated Newtons or I have collimated SCTs or whatever scopes before... It seems that my laser tells that this little RCT has a very slightly mis-collimated secondary, so I can finish its' collimation in no time.
Let's try it before taking this baby under the stars.."
I myself even had purchased this Takahashi collimation scope with the RCT scope, because it's a well known high-quality and very accurate collimation device. I had also my Howie Glatter holographic laser with many different attachments available in my usage too. (All these were very high quality collimation tools, just like CatsEye XLKP etc. Cheshires.) When I put them into this new RCT scope's focuser, won't these tools give me better collimation to my new RCT scope, because I know what I'm doing with them? Right? But what good did they make there with my RCT collimation at that stage... nothing, but ruined my nearly perfect RCT factory collimation
Eh... you can see where this leads, because all astronomy related forums around the globe are filled with queries for RCT collimation issues. And whenever more information comes from the message thread, then the story goes most often this way: "I have used my collimation tool X with my new RCT scope and now the star field has weird star shapes. I have tried to use my scope's collimator tools to get my secondary/primary mirror collimated... etc. and I'm getting nowhere. Please help me!"
My humble wish here is that every new RCT owner would at least read this DSI guide ("A Procedure for Collimating Ritchey‐Chrétien and Other Cassegrain Telescopes") and then just take some test pictures from star field with their RCT/camera combo (=without taking any adjustments to their RCT scope). DSI guide helps oneself to understand the secrets about RCT optics and guides you how you can use these aberrations into your advantage. Highly recommended, IMHO.
That quide has also an excellent paragraph called "Problems with the Traditional <collimation> Method", which describes exactly ALL the mechanical issues, which these Chinese RCTs might have and why the usage of any tradional collimation tool is highly likely to fail with these RCT dual-hyberbolic optics. In addition to these scope mechanical flaws, there's always the unavoided user-error possibility, when beginner is fixing his tradional collimator tool into scope's focuser. For example getting this laser view from RCT is highly dependant from the Howie Glatter laser's own position in the standard Chinese RCT focuser. When you will know, that your collimation tool is attached to the focuser as straight as possible without any tilt??? For example I cannot quarantee my Glatter laser alignment in my Starlight Instruments FeatherTouch focuser even with Glatter's own Parallizer adapter. I know, that there's always a slight movement tolerance for attaching these collimator tools to any focuser without threads and this "allowed" tolerance is a bit too much for accurate RCT collimation needs, I think. You can get up to 90% collimation results with these tools, but what does it help, if your RCT scope had before some 96% collimation accuracy from the (Chinese) factory line?
I have often referred RCT collimation to "walking on the wire couple of meters above the ground level". There's a very narrow area, which keeps RCT collimation in balance and when you slip away from that perfect collimation point (optimists say "area"
), then your perfect collimation starts to fade away very rapidly. And with any separete collimation tools I have tried here with my RCT I could not get my RCT scope fully collimated (ie. better collimated than with this "frustrating" DSI method). These generic collimation tools are good enough for getting your focuser lined up and check your basics with RCT collimation. You can probably get your RCT optics rougly (maybe up to 90 %) collimated with these tools but nowhere closer, because they usually fail for the reasons described in the DSI collimation method guide. (Disclaimer: you can be very glad, if you can disgree with myself here on RCT collimation tools, because that would help things a lot. But no such luck happened here...)
Anyway, RCT fine collimation can also be adjusted with a cardboard peep-hole and "walking the line" (=optical axis) in the front (and back) of your RCT scope. No additional tools needed (just your eyes, cardboard and your hex keys + nearby neighbours, who think you're crazy ;-), because viewing those internal mirror reflections from different distances away from your RCT scope is a very very sensitive way of checking your RCT collimation during daytime. (It's actually the same principle for any optical bench used in those assembly lines for RCT scopes, I guess.) For the reference, I have received this kind of results with my daytime collimation attempts only, but the mirror adjustments during daytime are much harder to understand than in the night collimation with the DSI method.
Anyway YMMV... (it took years of practise from me to get here from there)
PS. Quote: "If a person has a GSO scope collimating that way is virtually impossible because of the primary mirror mechanics."
Is this really true? I had forgotten that aspect, because I had separeted my focuser from the primary, before I found the DSI method guide.
Edited by Timo I, 03 July 2020 - 12:31 PM.
