I was given what appears to be a Tasco 4TVE by a very kind and generous CN'er. Because of the type of optics (variable power erecting zoom), I decided to do a conversion to a standard refractor. The objective is quite good and the auxiliary lenses in the variable power optics degrade the image quality by a fair amount. After I applied some muscle with a pair of strap wrenches, I got the dew shield and objective cell removed. They were on there awfully tight. After I cleaned the cemented objective, I ran a DPAC test on it. Here is the Ronchigram:
It compares quite well with my 40mm Royal R-42.
The biggest problem with converting these types of scopes is the focusing mechanics. Because of the design of these variable power setups, the native focal length of the objective is considerably shorter than the combined objective/variable power combo. I had to shorten the tube by about 6.25" to reach focus with a diagonal.
Unfortunately, the original eyepiece threads onto the focuser tube and it's an oddball size. Attaching a standard .965" diagonal was a challenge.
I discovered that a thin-wall .965" barrel give a very solid press fit onto the focuser draw tube.
So far, so good. The next step was to take a standard .965" diagonal and use the eyepiece receiving end to fit onto the now-expanded draw tube.
The last piece of the puzzle was to unthread the other end of the diagonal that would normally be inserted into a draw tube and locate another eyepiece receiver from a different diagonal that has the same threads. As you can see in the previous photo, I found a split ring one that works just fine.
While testing the setup, it was obvious that the draw tube wasn't blackened, so I flocked it and now it's an excellent little scope.
Now, it's time to strip it all back down for a repaint.
