Dumb question on hooking up ASI cameras and the ASIair
4 replies to this topic
#1 hawkman
hawkman
  • Loc: Saint Helena (Napa Valley), California
Posted 03 July 2020 - 06:12 PM
Hopefully someone can help me with a dumb question.  I'm finally getting around to hooking up the ASI cameras I purchased (290MM guide camera and 294MC color camera) to the ASIair I'd like to use to control the whole rig.  It would seem to be so simple but nowhere can I find clear directions on where to hook up the 290MM guide camera - does it connect to the 294MM camera or directly to the ASIair?  ASI's own video says hook the guide camera up to the ASIair, then shows it hooked up to the main camera.
It's probably out there somewhere but I can't find it.
Thanks for any guidance on this.
John Hawkins
#2 scopewizard
scopewizard
  • Loc: Alberta, Canada
Posted 03 July 2020 - 06:21 PM
If you imaging camera has an USB hub build in ( normally on cool camera) and connected to 12 vdc for the cooler, you can hook the guide camera to the imaging camera otherwise connect it to one of the ASIair USB.
#3 redline96
redline96
Posted 03 July 2020 - 06:41 PM
you can do it either way.  directly to the 294 camera usb port or to the Asiair usb port.
#4 hawkman
hawkman
Posted 03 July 2020 - 07:29 PM
Thanks - interesting that it works either way.
#5 YAOG
YAOG
  • Loc: Southern California
Posted 05 July 2020 - 12:13 AM
John Hawkins
It works fine either way so use the path that gives you the best cable routing.
