NGC 292 mosaic - work in "progress"
3 replies to this topic
#1 imtl
imtl
Posted 03 July 2020 - 08:50 PM
Hi all,
I decided to go for a "big" (for me) 3x3 mosaic of the small Magellanic cloud. I tested my run on a clear night with a big moon so I can
work out all the tweaks needed. Which was a good idea! Because there is a lot to learn with mosaics. I don't know how the people with 40+ panels do
it but I salute you all.
Anyways, I followed some excellent advice here on CN and I got to the best point I can with the L. When I write best, I mean with getting the best matching panels in matters of seeming and noise level. I do want to emphasize that I only took about 30 minutes data on each panel because I was testing things out so it might be that because of the noise level the differences are enhanced.
The processing was a new thing to learn and it take a huge amount of time to do it. I haven't even started working on the RGB or even to actually process the L besides a simple stretch to post here with my questions.
Here is the big image stretched with masked stretch and then some HT and curves.
LumRawMosaic
What is bothering me is that if I pixel peep I can still see the seeming and the differences between the panels.
seem
Do you have any advice on what setting to you so I can make this better?
When I took the subs I took them all in one night. half hour per panel. I finished that and then I started another cycle of 15 minutes more on each panel. I thought that this way I will average out to the best I can the changing conditions. Seeing was really steady and good the whole night giving me an average RMS guiding of 0.66"/pixel. My image scale is 1.14"/pixel so that pretty good for me.
Any thoughts and advice on how to proceed would be very much appreciated.
Eyal
  • elmiko likes this
#2 vnc1218
vnc1218
Posted 03 July 2020 - 09:29 PM
How did you combine them in this image?
#3 imtl
imtl
Posted 03 July 2020 - 09:59 PM
I created a starfield, aligned each panel, linear fit each to the central panel using the dnalinfit.
Then I used GMM to create the mosaic
#4 imtl
imtl
Posted 05 July 2020 - 05:44 AM
Gosh, this was exhausting. Finally I got this thing under control (and learned more PI on the way). I went back to the original panels and realized I was doing the ABE/DBE wrong. I worked carefully building it panel by panel and equalizing the histograms. Once I got that done the seeming of the mosaic was good. You really need to pixel peep to see the seems. Once I acquire more data then the noise STD will be narrower and the differences between the panels will shrink more. I estimated the noise differences and I got to the best point I can with this data. I think it has potential.
I've done Lum and blue. Just thinking that now I need to do the same for red and green.... At least I got a workflow going that
seems to give me consistent results.
I need a break from PI smile.gif Too bad its going to be cloudy for another week! That forces me to process images instead of acquiring data!
I hope to get a full LRGB image soon.
Edited by imtl, 05 July 2020 - 05:56 AM.
