Hyperstar - Do I need to collimare again?
3 replies to this topic
#1 Daniele
Daniele
  • Loc: Tuscany, Italy.
Posted 04 July 2020 - 08:59 AM
When I used the hyperstar and then remounted the secondary mirror, do I need to collimate it from zero?
I don’t think so because when I remove the secondary mirror I don’t touch the screws.
Best regards
#2 descott12
descott12
    Vendor - Solar Live View
  • Loc: Charlotte, NC
Posted 04 July 2020 - 10:53 AM
My HS had been installed and removed probably 100 times now and it never affected the collimation.
#3 JohnBear
JohnBear
  • Loc: Sandy, Utah
Posted 04 July 2020 - 10:57 AM
If you want good images you should 'check' collimation each time you use the telescope -  that is easy.  If it 'checks' OK  you are good to go. However if the 'check shows that collimation is off, "Adjusting" the collimation involves a whole lot more than 'checking' - as you should know.
#4 Daniele
Daniele
Posted 04 July 2020 - 11:32 AM
Thanks guys!
