Sequence generator Pro won't start
7 replies to this topic
#1 homerdt
homerdt
  • Loc: Astoria, Oregon
Posted 05 July 2020 - 02:48 AM
Hello, I'm not sure this is the right place to ask but I went to start things up tonight, my primary imaging program SGP won't start. The little hour glass flashes when I click on it and nothing, I've restarted my computer, nothing. I've uninstalled and reinstalled it, nothing. I've tried to run it as an administrator, nothing. I'm at a loss, has anyone else run into this and what was the fix? First clear night for weeks and now this, GEEEZ...
Edited by homerdt, 05 July 2020 - 02:49 AM.
#2 imtl
imtl
Posted 05 July 2020 - 02:55 AM
Disable your firewall and antivirus. Try again.
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 05 July 2020 - 03:00 AM
See in log file what is the last (error) message.
C:\Users\[your username]\AppData\Local\SequenceGenerator
Here are some tips:
http://forum.mainseq...n-at-all/9183/5
And this:
http://forum.mainseq...-10-solved/8236
#4 nemo129
nemo129
  • Loc: WMass
Posted 05 July 2020 - 12:25 PM
You will probably get a lot more help regarding this issue on the Main Sequence forums than you will here. Make sure you upload your logs in your post.
#5 homerdt
homerdt
Posted 06 July 2020 - 12:16 AM
Here are some tips:
And this:
Thanks for pointing me in the right direction, found it and in time to get some imaging in. First clear night for a while and me with a new dual band filter to try.
#6 homerdt
homerdt
Posted 06 July 2020 - 12:17 AM
Thanks to all that responded
#7 Tapio
Tapio
Posted 06 July 2020 - 12:24 AM
What was the cure ?
#8 homerdt
homerdt
Posted 06 July 2020 - 02:39 PM
What was the cure ?
it was a corrupted file, deleted it and everything worked fine.
