Ioptron AZPM pro "latest woes"
25 replies to this topic
#1 coconut
coconut
Posted 05 July 2020 - 03:59 AM
I have just about had it with this mount.After 6 months of ownership and frustration I am ready to throw in the towel.Board and gps swap ,az/alt cable swap,firmware updates,gear adjustments....are some of the latest things I have tried.Every night something different pops up to ruin a session.Tonight for example I can slew from mars or saturn to jupiter and its bang on everytime GREAT but try going from jupiter back to saturn or mars = a big FAIL ??.Ioptron has been great with timely replies and suggestions,but the results has not improved one thing.Since it is still under warranty,my option is to send it back for a look over.This means for the short summer observing season and sending it over the border chances are that a big chunk of it will be missed this year.This is no fun and I did not see this coming.Sad sad sad....
  • retroman2 likes this
#2 jloweva
jloweva
Posted 05 July 2020 - 05:24 AM
I would insist on a new one.  No reason you should have to do any of those things on a brand new product, and certainly not all of them.
#3 coopman
coopman
  • Loc: South Louisiana
Posted 05 July 2020 - 12:55 PM
There are always enough bad comments about this mount to keep me from ordering it. I'm sad to hear that your experience with it has been so unpleasant, but thanks for letting us know.
#4 ScottW
ScottW
Posted 05 July 2020 - 01:31 PM
Clay,
I second your thoughts.
Scott
#5 jloweva
jloweva
Posted 05 July 2020 - 02:42 PM
FWIW, I’ve had two, both of which have worked flawlessly. But like much in life, I guess it’s luck of the draw.  I’ve had great experience with the folks at iOptron, and for the money there’s simply nothing else like the AZMP: dual saddle option, built in gps, built in battery, etc.  It’s a remarkable piece of equipment.
I’m sorry you’ve had a bad experience. I hope they resolve it to your satisfaction.
  • Spikey131 likes this
#6 coconut
coconut
Posted 05 July 2020 - 03:13 PM
Thanks fellows
Yes I have not given up just yet.It has alot of the features I was looking for and Ioptron service has responded when I called on them.We will see what developes in the coming weeks and I will report back.I have been using astro equipment for the last 30 years from Celestron,Meade,Starmaster and so on and I have to say this one has been the most challenging one in past memory.I am a patient man and willing to go the extra mile to figure things out.
 like they say "there's always hope"
#7 dustyc
dustyc
  • Loc: Phoenix,AZ
Posted 05 July 2020 - 03:16 PM
I had 2. The 1st worked perfect for about 2 weeks. Then the saga started. Ioptron is good about service. But I really think they need a gifted electronics and/or board designer to look at things. The mechanics are so simple on this mount. It should be easy to get these consistently good.
#8 gilbert80
gilbert80
  • Loc: Tonawanda, NY
Posted 05 July 2020 - 03:44 PM
I have this setup and love it, I observed more objects with it and a ES127 Triplet
in one night than I have ever found in my life, I am 72 years old.  The only problem
I have had is I lost the first two lines on my led display after not using it for three
months this winter. The battery, 3VCR 1220 went bad and I haven't changed it
yet, I understand that "maybe" I can us a CR2032.  Any suggestions?  Could the
little battery in your handset be the fault?   All the best!
#9 ArneN
ArneN
  • Loc: Norway
Posted 05 July 2020 - 03:51 PM
I have had mine for almost three years. IT stays outside under a Telegizmo and never fails. Just switch IT on and ready to go. No need for any alignment either. Ends every session by sending the mount to zero position and ready for the next night. No need for a finder either, just controll everything from SkySafari.
But a battery for the HC might be a way to solve issues.
Arne
#10 biz
biz
    Vendor
  • Loc: New Zealand
Posted 06 July 2020 - 02:56 AM
Mine has worked faultlessly straight out of the box for around three years and I’m even using an older firmware that’s doing everything that’s needed to be done. It has been highly accurate in targeting and tracking since it was first powered on.
Ive also only had one unit dropped into my home workshop for a look see  since it’s release and all that was needed was a simple adjustment. Not sure why some are having these issues they are complaining about..
cheers
Graham
#11 sewhite
sewhite
  • Loc: North Georgia
Posted 06 July 2020 - 09:28 AM
I believe that it's time to start pushing for a replacement.   You are doing iOptron's service and repair for them.    They may not replace it,  but if it were mine, that's what I would do.  Be nice but steady and firm on getting a replacement.
Hope you and iOptron get this resolved.
Stan
#12 coopman
coopman
Posted 06 July 2020 - 10:15 AM
Please report back & let us know how this turned out. Thanks.
#13 dhkaiser
dhkaiser
Posted 06 July 2020 - 10:22 AM
Mine worked great, for 3 months.  It then started jumping while tracking with a clicking noise, same problem mentioned in this forum by several individuals.   Ioptron sent instructions to adjust the drive.  After two failed attempts to adjust the drive I sent it back.  They have had it in their shop for 13 days and have not responded to inquiry as to when I might expect it's return.
#14 coconut
coconut
Posted 06 July 2020 - 10:32 AM
 Dan
Funny every night I take mine out to see what will happen...
Last night it started jumping also for the first time !
I hear the az motor engaging but 80% of the time no movement,I have to move to a higher speed to bump it and then it might work on low maybe...
#15 dhkaiser
dhkaiser
Posted 06 July 2020 - 09:17 PM
Got a reply from Ioptron today saying my mount is being shipped back today.  Also "Service log indicates that both AZI worm assembly with motor was replaced, as well as the battery."  I think that sounds promising, we will see.
  • jeremiah2229 likes this
#16 coconut
coconut
Posted 07 July 2020 - 03:37 AM
Hope it works out for you Dan.Would you know what serial # yours is (sticker under the base) ?
Apart from the jumping did it not move in az sometimes ?
#17 dhkaiser
dhkaiser
Posted 07 July 2020 - 07:09 AM
Don't know the number, and no just the jumping and clicking.  I can see why the drive adjustments I did did not work if they had to replace the drives.
#18 StarAlert
StarAlert
  • Loc: Claremont CA
Posted 08 July 2020 - 11:04 AM
My AZ pro was clicking/jumping while tracking a couple nights ago. First time it has done that. I figured out quickly that my scope wasn’t balanced properly. I was using a longer dovetail and had to push the scope forward to clear the mount. I re-balanced the scope and problem was solved.
Edited by StarAlert, 08 July 2020 - 11:04 AM.
  • biz, Xeroid and Spikey131 like this
#19 dhkaiser
dhkaiser
Posted 10 July 2020 - 08:59 AM
Ioptron returned my mount yesterday and today I successfully observed the sun off and on between clouds for about an hour.  Tracked well and no jumping or noise viewing at 100x.
  • StarAlert likes this
#20 coconut
coconut
Posted 10 July 2020 - 09:48 AM
Good to know.I think I will have to send mine in.Can I ask you what firmware your running ?
#21 dhkaiser
dhkaiser
Posted 10 July 2020 - 09:54 AM
HC V2 190429, Main 190618
#22 coconut
coconut
Posted 10 July 2020 - 10:04 AM
I updated mine the other night to the latest to see if it would clear some issues.
HC 200113
Main 190618
Now I lost the wifi with Skysafari ?
 Not sure if I have access to previous versions on there site,can't find it.
Happy for you,looks promising !
#23 dhkaiser
dhkaiser
Posted 10 July 2020 - 10:07 AM
The dreaded "upgrade".
#24 Xeroid
Xeroid
  • Loc: USA
Posted 10 July 2020 - 10:19 AM
Check your Network SSID name, are you connected to the AZ Pro prior to running SkySafari?
Then check your SkySafari telescope settings.
HC 200113
Main 190618
Edited by Xeroid, 10 July 2020 - 10:22 AM.
#25 coconut
coconut
Posted 10 July 2020 - 10:24 AM
Thanks Xeroid
Those are the first things I checked even did a factory reset and tried it with SS5.Still no go.
