Polemaster without the polemaster?
20 replies to this topic
#1 bmbaum
bmbaum
Posted 07 July 2020 - 12:25 AM
I don't own a polemaster, but it seems to me that the same routines used by the polemaster software should work equally well through the OTA/camera as opposed to the polar scope. As long as the OTA is aligned precisely with the polar scope, why do we need the $350 polemaster camera at all?
#2 Ken Sturrock
Ken Sturrock
    Cardinal Ximenez (No one expects the Spanish Inquisition)
  • Loc: Denver, CO
Posted 07 July 2020 - 12:27 AM
Some people like buying extra gadgets. For everyone else, there's the Sharpcap alignment process (or others). :step:
  • elmiko, zxx, Wintermute and 3 others like this
#3 terry59
terry59
  • Loc: Colorado, USA
Posted 07 July 2020 - 05:59 AM
There are some differences betwen Sharpcap and PM, such as the ability to measure and store cone error. It reminds me of the inability to store settings in APP
  • elmiko, bobzeq25 and OhmEye like this
#4 1965_dup1
1965_dup1
  • Loc: NC
Posted 07 July 2020 - 08:46 AM
Polemaster is a great tool and I just love mine, simplicity .
  • cosmo59, drd715 and Rudix like this
#5 idclimber
idclimber
  • Loc: McCall Idaho
Posted 07 July 2020 - 09:29 AM
Not only is a Polemaster not needed, a view of Polaris is not needed either. Programs like TheSkyX used with the Paramounts use a model created by plate solving images all over the sky. Only about 30 to 40 points are needed for a portable realignment of a larger pointing model that was created previously. This usually only takes about 15 minutes and creates a solution to correct the mount and provide excellent polar alignment.
Edited by idclimber, 07 July 2020 - 09:30 AM.
#6 bobzeq25
bobzeq25
Posted 07 July 2020 - 09:36 AM
I got a PoleMaster when they first came out, before Sharpcap was an option.  It's extremely simple and works very well.  These days many like Sharpcap because it's free and also works.  Just a personal choice.  PoleMaster, I think, is a bit better (just like their software), but costs $300, and the free Sharpcap does the job.
I think the new iOptron iPolar is the best yet, it too costs money, and is, I believe, only available with certain iOptron mounts.  I think there's also something in PhD2.
The bottom line is that there are now a number of alternatives that can all do polar alignment better than most people need, rapidly and easily.
Edited by bobzeq25, 07 July 2020 - 09:40 AM.
#7 khursh
khursh
Posted 07 July 2020 - 11:06 AM
FYI. Sharpcap Pro which has the PA routine is not free, it is 10GBP (about $14) per year.
#8 chadrian84
chadrian84
  • Loc: Wisconsin
Posted 07 July 2020 - 11:18 AM
Do long FL scopes (narrow FOV) work with sharpcap? I don’t use guide scopes, OAG only. I have 3 pole masters which work well but using the main scope camera makes sense if it works.
#9 RandallK
RandallK
  • Loc: Nanaimo, B. C. Canada
Posted 07 July 2020 - 01:02 PM
I have PoleMaster and now iPolar in my CEM-40 mount and yes, you are correct...the iPolar is about 1/2 hour more sensitive in capturing Polaris and setup is soooo much quicker. For us folks farther north, it gives us more critical imaging time!
#10 Umasscrew39
Umasscrew39
  • Loc: Central Florida
Posted 07 July 2020 - 01:18 PM
As long as you have a FOV of 1-2.5 degrees, are within 5 degrees of the Pole, and can see 15 stars, SC will work.  That is why Robin recommends a guide scope with around a  200mm focal length.   I actually use the Polemaster camera with SC to align with the Pole.  I find the SC software easier and quicker to use.  With that said, I have compared PoleMaster, SC, and the old painful gold standard, drift alignment in my observatory and all three are very close.
#11 OhmEye
OhmEye
  • Loc: Western NY Southern Tier
Posted 07 July 2020 - 02:46 PM
I always seem to have some uncommon stuff to deal with! :) This time of year the PM software is usable to me about 40 minutes before I start imaging. My main imaging location in my yard has tree branches in the view of Polaris, and I can use the PM software much sooner than Sharpcap because while the sky still has brightness the edges of the leaves and branches fool Sharpcap's star detection and it fails to solve until it gets dark enough to not see the tree. This doesn't bother me though since I prefer to use PM anyway since it remembers the cone error and doesn't go through a rotation routine to find it every time it's used.
#12 robbieg147
robbieg147
  • Loc: Kent, England
Posted 07 July 2020 - 03:20 PM
With the Polemaster I know I am aligned before mounting the scope. It is also so quick only a couple of minutes and so accurate. Once I started using the Polemaster I could get 3 minute subs unguided with my AVX.
Edited by robbieg147, 07 July 2020 - 03:21 PM.
  • bobzeq25, drd715 and Rudix like this
#13 nimitz69
nimitz69
  • Loc: A barrier island 18 miles south of Cocoa Beach
Posted 07 July 2020 - 05:26 PM
You don’t, you only need a $15/yr subscription to SharpCap Pro and your guidescope and guide camera
Edited by nimitz69, 07 July 2020 - 05:48 PM.
#14 OhmEye
OhmEye
Posted 07 July 2020 - 06:37 PM
Indeed you don't. It's simply a luxury. Having a camera permanently mounted on the mount in a fixed position that doesn't change alignment with the RA axis doesn't require going through a camera alignment routine every time to find the cone error. I wouldn't recommend a Polemaster if budget is an issue but I enjoy the indulgence. People spend 2-3 times what I think is reasonable for an automobile, and I have a dedicated camera that shaves a few minutes a month off my PA time. Humans. We're weird.
#15 SoDaKAstroNut
SoDaKAstroNut
  • Loc: Black Hills, South Dakota
Posted 07 July 2020 - 08:38 PM
...at only $9,000, plus tax & shipping. I will stick with my trusty PoleMaster until I hit the lottery.
#16 idclimber
idclimber
  • Loc: McCall Idaho
Posted 08 July 2020 - 02:51 AM
TheSkyX imaging addition is $495. It also works on most mounts. You do not need a Paramount to do this.
#17 terry59
terry59
Posted 08 July 2020 - 06:43 AM
I've had a few occasions when I've gotten a bad alignment with the PM and it is nice to be able to redo the alignment on the fly
#18 WebFoot
WebFoot
  • Loc: Redmond, WA, USA
Posted 08 July 2020 - 03:23 PM
I'm a big fan of "easy."  Especially in a hobby where so little is "easy."
I used to do a drift polar alignment.  Works great, and doesn't take a long, long time.  But it's annoying, and does take time away from using the scope.
I bought Polemaster a year ago.  My only regret is that I didn't buy it years earlier.  I don't know of the other computer aids (other than Tpoint, which takes a long time), so I can't compare, but I can say that Polemaster is that rare tool with software that just works, and UI that is easy and intuitive.
I like easy.
Mark
  • Rudix likes this
#19 nimitz69
nimitz69
Posted 08 July 2020 - 06:53 PM
Or just go with the $15/yr SharpCap option ... smile.gif
#20 pbmazda32
pbmazda32
  • Loc: Central Alabama
Posted 09 July 2020 - 05:47 AM
I've had three back surgeries and now I'm looking at a neck surgery. It's painful and difficult to get down and look through that tiny polar scope. I bought the ipolar and it's been wonderful.
#21 freiform
freiform
Posted 09 July 2020 - 08:52 AM
There's also EKOS which has a PA routine similar to SharpCap. And it's free as in beer AND speech. It's requires you to use INDI, so your hardware has to be connected to a Linux system (or a Mac). EKOS itself will also run on Windows, though. And it can control the hardware through the INDI server.
CS
Sven
