Vixen R200SS - what am i doing wrong
2 replies to this topic
#1 lucian nicu
lucian nicu
Posted 07 July 2020 - 04:41 AM
Hi all.
Hoping that someone can help me with some advice, I attach here a short presentation of the problem, as well as 3 photos as samples.
I recently bought a Vixen R200SS (an older model - picture attached) and, after washing the mirrors and collimating, I hoped to put it to work. I was unable to reach any results although I tried to use both the dedicated coma corrector (picture attached) and a Baader coma corrector (MPCC Mark III). I don't realize what I'm doing wrong. The last option would be to purchase a newer coma corrector and a dedicated adapter (links attached). But I'm not sure this will solve the problem. Because my experience with Newtonian telescopes is very limited, I wonder if it would not be possible for this problem to be from the telescope.
So, any advice will be welcome and, of course, appreciated.
Thank you very much.
Newer coma corrector - https://www.vixenopt...ope-p/37226.htm
Dedicated adapter - https://www.vixenopt...pter-p/2954.htm
Attached photos :
1. Telescope.
2. Coma corrector ( which i already have ).
3. Photo using the Vixen coma corrector.
4. Photo without any corrector.
5. Photo using the Baader MPCC Mark III coma corrector.
Edited by lucian nicu, 07 July 2020 - 04:44 AM.
#2 K.K
K.K
Posted 08 July 2020 - 11:51 PM
There are plenty of people shooting with the R200SS and Baader MPCC Mark III.
https://www.astrobin...arch/?q=R200SS mpc
The distance from the T2 thread of the MPCC to the camera sensor should be 55mm. If the distance is too close or too far, it will not compensate properly.
https://www.baader-p...r-newtons).html2-mpcc-mark-iii-multi-purpose-coma-corre
#3 sixela
sixela
  • Loc: Boechout, Belgium
Posted 09 July 2020 - 07:17 AM
Ditto. The spacing between the coma correctors is critical, and you also have collimation issues (tilted focal planes, coma on the centre object) that are independent of the use of a coma corrector (and in the first image probably guiding or field rotation issues too, i.e. mount alignment issues).
