Mounting an Explore Scientific ED80 onto an ADM bar (on C11)
6 replies to this topic
#1 kevinbreen
kevinbreen
  • Loc: Wexford, Ireland
Posted 07 July 2020 - 02:10 PM
I want to be able to piggyback my ED80 on top of my C11 in case the seeing is so bad that the C11 is no good for planetary and I can try capturing smaller images with the ED80 without the hassle of dismounting the C11 from my EQ6 mount.
Here's a pic of the ADM bar and the dovetail of the ED80.
It's an 18" long MDS-C11- MDS Series Dovetail Bar.
Can anyone suggest a method of mounting the ED80 onto the ADM bar? Is there some kind of intermediary clamp available somewhere?
Many thanks!
Kev
#2 jeffreym
jeffreym
  • Loc: La Crosse, WI
Posted 07 July 2020 - 02:40 PM
pgrunwald posted this image.  I have a similar setup on my LX200 but I did not have a picture.  ADM bar mounted on top with a set of ADM Vixen guidescope rings and clamps.
If you didn't want them to be aligned, you could attach the clamps to the dovetail that might already be mounted to the ED80, so the same setup without the rings.
Jeff
Edited by jeffreym, 07 July 2020 - 02:43 PM.
#3 johnoelliott
johnoelliott
  • Loc: Toronto Ontario
Posted 07 July 2020 - 04:08 PM
I use an ADM mini guider to mount my 80 mm on the ADM bar on top of my 11
  • jeffreym and kevinbreen like this
#4 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 08 July 2020 - 12:25 PM
Try these:   You will want to put a better dovetail bar on the scope as well.
#5 kevinbreen
kevinbreen
Posted 08 July 2020 - 12:41 PM
Did you mean to attach a pic?
#6 EFT
EFT
  • Loc: Phoenix, AZ
Posted 08 July 2020 - 01:33 PM
OK.  Now I know that links are disappearing when I place them in a post.  This isn't the first time this has happened recently.
Here's the link (hopefully):  https://www.stellarvue.com/risers/ .  Otherwise, the link is to the Stellarvue risers.
#7 kevinbreen
kevinbreen
Posted 08 July 2020 - 01:45 PM
Great, thanks very much. That's by far the cheapest method I've seen so far.
