Any experience using astro autofocus software with DSLR lenses?
astrophotography dslr equipment
6 replies to this topic
#1 nathanm
nathanm
Posted 07 July 2020 - 02:43 PM
There are numerous software packages that will autofocus a telescope by taking photos and judging where the minimum size star disk is.   This includes Focus Max as a dedicated focus application, and/or features within telescope and camera control software like APT, NINA etc.
I use Canon DSLR - astro modified 5D Mark IV, and more recently a QHY 128c with Canon mount.   I use Canon and other Canon-mount lenses from 14mm to 200mm.
I already found that using a stepper motor with a Cine-style follow-focus gear on the lens can step much more finely than I can by hand.   I did this "manually" meaning I am still judging the spot size by eye.  But the stepper motor is much better than turning the ring.
But once I am there I thought hey, why not do autofocus with the same software that one uses for telescopes.
I believe the simplest way to do that is to get an ASCOM compatible controller for my stepper, like this https://pegasusastro...tor-controller/  and then use one of the many software approaches.
What is your experience doing this?   Is there any software that is particularly good in this case?
#2 2ghouls
2ghouls
Posted 07 July 2020 - 03:40 PM
https://sourceforge....focuserpro2diy/
For your Canon lenses mounted to your QHY 128C, this is the better solution though IMO: http://astromechanics.org/ascom.html
#3 nathanm
nathanm
Posted 07 July 2020 - 06:35 PM
The Astromechanics Canon lens interface is very interesting and I do use it with QHY.
That allows controlling the aperture, and also the focus motors if it is an autofocus lens.
However, most of the lenses that I use are NOT autofocus lenses.   They are manual - like Zeiss or Samyang/Rokinon.   So this approach does not help for them - that is why I use a cinema-style follow focus gear on the lens, engaged by a stepper motor.   Which can then be driven by a manual controller to bump focus by a tiny amount.
My hope is that I can use it with astrophotography autofocus software.  Which in principle should work.
#4 2ghouls
2ghouls
Posted 07 July 2020 - 07:18 PM
Yes, I understand. The first link I provided is an Ascom driver for controlling a stepper motor through an arduino board that should work for you
Sent from my VOG-L29 using Tapatalk
#5 nathanm
nathanm
Posted 08 July 2020 - 12:02 AM
#6 Iamhondo
Iamhondo
  • Loc: Salem, MO
Posted 08 July 2020 - 07:10 PM
You have several answers, but I'll throw in a couple more.
First, tools like EOS Utility and Backyard EOS have the ability to adjust the focuser (via computer control) of a Canon EOS camera with a Canon lens. Neither does autofocus. Other programs interface to EOS DSLRs -- like APT. I don't know which if any will do autofocus for an EOS camera/lens combo. I think you have several references to an interface that would allow you to connect and focus a Canon lens with non-Canon cameras, like ZWO and QHY. Some tools can adjust aperture, too.
Second, I'm experimenting with the Tilta Nucleus-Nano wireless focuser. This is designed for film production, not astrophotos. I've mounted my ZWO camera with a Nikkor 180mm AIS lens. The focuser allows me to make micro adjustments using the hand controller, but not with a computer (afaict). That's not a huge drawback. Once I get precise focus on my lens, I lock that focus for the night.
Here's a short demo video of the Nano: https://www.youtube....h?v=CkOhuQYDYtw
HTH,
Joe
#7 nathanm
nathanm
Posted 11 July 2020 - 02:24 PM
I am currently using stepper motors designed for cinematographers similar in spirit to the Tilta Nucleas-Nano - they are just not wireless, and are controlled either with a hand controller, or via software on a PC, but not autofocus.
Basically what I want to do is use the cine-style steppers with an ASCOM driver and astro autofocus software.  I've been messaged by people who do similar things so I think it will work.
Also tagged with one or more of these keywords: astrophotography, dslr, equipment
