Multiple Profiles in NINA
2 replies to this topic
#1 TXDigiSLR
TXDigiSLR
  • Loc: Dallas, TX
Posted 07 July 2020 - 04:13 PM
I love NINA, I've finally figured almost everything out that I need, including the awesome Flat Wizard, but I have two issues I know someone here will be able to fix for me.
First, I have an ASI 1600mm Pro and a 7 position filter wheel.   When I shoot LRGB I use gain 76, offset 15, and when I shoot NarrowBand I use gain 139, offset 40.
I set up two different profiles, one for Wide and one for Narrow, but the Default Gain, Default Offset do not change when I change profiles.  They stay the same as the last time I modified them, no matter which profile I use.  I am beginning to think when I connect the camera to NINA, it remembers the last values I had set as defaults, or maybe it's saved to the ACSOM Camera Driver, (which would be the same driver for both profiles.)
Is there a way to make this work, or a way for forgetful me to not have to constantly worry about checking and switching my gain and offset depending upon what I shoot?
Second issue...   My EFW...  I have it all set up for step size, backlash, etc, however, in NINA  the Mas Step and Max Increment are set at 65000 (which is too large)    When I hit the gears for the config, I have the Max Step set at 30000.   Why doesn't this stick in NINA?
Thanks for any info!
#2 OhmEye
OhmEye
  • Loc: Western NY Southern Tier
Posted 07 July 2020 - 04:19 PM
What version NINA?
  • scadvice likes this
#3 TXDigiSLR
TXDigiSLR
  • Loc: Dallas, TX
Posted 07 July 2020 - 04:44 PM
What version NINA?
The latest 1.10 RC
