C90 needs some TLC
5 replies to this topic
#1 ANM
ANM
  • Loc: El Paso, Texas, USA, Earth, Sol system, Orion-Cygnus arm, Milkyway
Posted 07 July 2020 - 04:36 PM
I recently bought a C90 Astro and sometimes it seems like the motor can't keep the C90 following the stars. I would guess that I need to disassemble the mount base, clean and relube the bearing surfaces. Is there a writeup on doing that somewhere? If I take the nut off the polar axle and pull the base apart are gears and springs and wheels going to go bouncing everywhere?
#2 jgraham
jgraham
Posted 07 July 2020 - 05:40 PM
Do you have the counterbalance weights for the tube when it is mounted in polar mode? If not, that may be why the tracking is struggling.
  • ANM and kathyastro like this
#3 houndsbourgh
houndsbourgh
  • Loc: Hailey, Idaho
Posted 07 July 2020 - 06:48 PM
I agree. Without the counterweights its quite an uneven load on the drive.
  • ANM likes this
#4 ANM
ANM
Posted 07 July 2020 - 07:49 PM
Yes I do have them and they are on the scope but with my messing around I've shifted the balance — I have to come up with a work-around. I think it will be ok if I can shift the weights rearward by a few inches. I'd still like to be able to pull the base apart and make sure it's all clean and lubed.
#5 ANM
ANM
Posted 08 July 2020 - 10:54 AM
I need to achieve a better balance with the C90, but I think the problem I'm seeing is a bad connection where the power cable plugs into the base. I have a second cable so I'll swap them and try my tests again.
#6 ANM
ANM
Posted 11 July 2020 - 08:30 AM
Yes! The eratic operation of the drive was due to the power cable. I swapped it with one from another telescope and I am not seeing the problem! The balance still needs to be corrected...
