Issue with Atik EFW3
2 replies to this topic
#1 zzchaozz
zzchaozz
Posted 08 July 2020 - 05:42 PM
Hello, I have a strange issue with my Atik EFW3 filter wheel. It is similar to the problem here
https://www.cloudyni...with-atik-efw3/
However, mine is stranger as it only happens after 1-2hours tracking. The wheel keeps moving to a wrong filter slots, sometimes recognises the wheel as 5 slots (though this is a 7 slot wheel). Moving to filter is very unreliable.
I checked everything, the cables are fine. There are not much dust inside the housing, the filters are extra secured with no loose movement. Has anyone had any ideas how to deal with this, aside from contact Atik for a repair.
I also have issues contacting Atik support. They never answer their email or something. Pretty frustration.
Thanks.
#2 Atik Cameras
Atik Cameras
    Atik Cameras
Posted 13 July 2020 - 08:14 AM
Hello,
Sorry to hear you are having problems getting through to our support, you should receive an automatic response from the from the support system, are you getting these.
It would be worth updating to the latest Atik core software which you can download from here https://www.atik-cam...ware-downloads/ We did discover a memory leak in the ASCOM plug in which has now been rectified. This was causing errors with the wheel after a few hours so this could be the problem.
Please let me know how you get on.
Best regards
Vince
#3 zzchaozz
zzchaozz
Posted 02 August 2020 - 07:33 PM
Hello,
Best regards
Vince
Thanks Vince,
I have updated the driver, check for faulty on my setup. I also noticed there was a small slug near the motor and spring. I tighten it down so the motor secure against the carousel.
The issue has gone, at last. However, when I track at 50-55 degree, the issue is back which is a bit annoying. What should I do to check for it? Do you have any ideas? As my place is in tight lockdown, it is pretty hard to send the wheel for repairing. It would take 4-6 weeks from here to the UK.
Cheers.
