Help with interpreting guide log issues
3 replies to this topic
#1 sonyshooter
sonyshooter
Posted 09 July 2020 - 07:20 PM
Help with interpreting guiding logs.
I have a Celestron CGX mount that is pier mounted.  Recently, I've changed from a Celestron 8SE to an Explore Scientific ED152 CF refractor on that mount.
When I had my 8SE on the mount, my guiding was always under 1.
Now, with the ED152 CF, I struggle to keep it below 2.\
It is polar aligned with a Polemaster and I've rebalanced it twice to try to settle down the guiding, but still it is very erratic.
I've attached my log file, drift analysis and frequency analysis from a 5 1/2 hour guiding session last night on Bode's Galaxy (M81).
I'm trying to identify the issues that I need to correct, but am not familiar with how to interpret log file results as I haven't had an issue before.
Any help to interpret what may possibly be going on would be appreciated.
Scott
#2 sonyshooter
sonyshooter
Posted 09 July 2020 - 07:22 PM
Here is the frequency analysis, it was too big to attach to the original post.
#3 imtl
imtl
Posted 09 July 2020 - 09:35 PM
You should post your actual log file and not screen shots. I can barely see the numbers in your images.
If you are referring to the spikes in RA that you get it could be several things. Check for cable snag.
  • jerahian likes this
#4 sonyshooter
sonyshooter
Posted 10 July 2020 - 07:30 AM
I tried to upload the log file, but it failed as it said that it is too big to be attached.
