Deep Sky Stacker and M8: only 7 images processed out of... 240!
3 replies to this topic
#1 kurtenstein
kurtenstein
  • Loc: Montréal
Posted 09 July 2020 - 07:28 PM
Hi! I'm an AP noob trying to figure something out. I chose the Lagoon Nebula as a target. I used a Fujifilm X-T20,a vintage 135mm f3.5 Super Takumar on a manually operated barn door tracker (type 1) to take 240 3-second exposures, for a planned total of 12 minutes. (ISO 1000) Using Deep Sky Stacker, I processed those images and added 10 darks and 10 offsets. 10 flats were planned... but I forgot to shine a light through my white fabric, so those were left behind.
Problem is... the final TIFF file in DSS doesn't seem much nicer than the indiviudual RAF (Fuji RAWs) files. M8 does stand out a bit more, but not that much. What annoys me the most is the fact that, at the end on the stacking process (it took hours!), it seems that only 7 images were stacked! [I use the French version, in case you wonder.]
DSS 7 images
#2 jgraham
jgraham
Posted 09 July 2020 - 08:22 PM
This happens if DSS has trouble locating alignment stars in the field. Try turning the sensitivity up by turning the threshold down. The default is 10%; try 5% or even 2%. If that fails try rescaling the images 50% to reduce the size of the stars.
#3 kurtenstein
kurtenstein
  • Loc: Montréal
Posted 10 July 2020 - 08:45 AM
Thanks! I'll try to turn the treshold down. Rescaling... the 240 pictures? Is there a way to do that at once? (Remember: I'm new to this...)
#4 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 10 July 2020 - 05:45 PM
Often DSS will reject stars that are not well-focused as well. This has happened to me, too.
Michael
