Ioptron Cube Pro GPS
mount
1 reply to this topic
#1 Afonso
Afonso
Posted 09 July 2020 - 09:20 PM
Hello guys from the forum, I'm having problems with my assembly, which is the ioptron cube pro 8408, he loses the link with the satellite frequently, I wanted to know if it happened to someone or if it is a defect of equipment or the region where I live, because the my yard where I make observations is a closed environment?
#2 Tom3
Tom3
  • Loc: Scottsdale, AZ
Posted 09 July 2020 - 11:12 PM
A gps needs at least 4 satellites to get a position fix, so if you are in a tight place that might be a problem. Try taking the mount to a location with a better view of the sky. If it is not a place where you want to do your astronomy you can test the system. Your can do it in daylight.
Also tagged with one or more of these keywords: mount
