Best software for large mosaic image capture?
astrophotography
8 replies to this topic
#1 nathanm
nathanm
Posted 10 July 2020 - 01:07 PM
A lot of astroastronomy programs
APT - Astro Photography Tool
SGP - Sequence Generator Pro
NINA - Nighttime Imaging N' Astronomy
Voyager
and probably others will automate image capture - programming the telescope mount to go-to a location, execute a series of photos with specified exposure time, then go to the next one etc.
I am interested in doing with this with both DSLR and a QHY camera and ideally I could use the same software for both.  That is why Backyard EOS is not on the list above.
I have only shot manually, or with a motorized panorama head in the past.   Now I am looking at a full equatorial go-to mount.
A lot of the mosaic software seems to be oriented around capturing a specific small target, and taking a few frames around it.  I am interested in doing large scale mosaics that could easily go up to 100 - 300 positions (also called panels or panes), with short to moderate focal length lenses.   The optics will be camera lenses 50mm through 200mm.
I would also like autofocus at the beginning of the mosaic, and possible even part way through.
Some mosaic planning software seems to be oriented around being used mainly before the imaging night.   While I might do that, I also want somethnig that isn't too hard to change or update in the field.
What are your experiences and recommendations?
#2 scadvice
scadvice
  • Loc: Lodi, California
Posted 10 July 2020 - 01:18 PM
I'll guessing N.I.N.A.
Since it's free I would download it and go on the discord site for advice. Also to start watch these videos.
https://www.youtube....v8apj_eXQ-tkuXG
Edited by scadvice, 10 July 2020 - 01:23 PM.
#3 ChristopherBeere
ChristopherBeere
  • Loc: London UK
Posted 10 July 2020 - 01:36 PM
[redacted]
Edited by ChristopherBeere, 10 July 2020 - 01:43 PM.
#4 psandelle
psandelle
  • Loc: Los Angeles
Posted 10 July 2020 - 10:15 PM
Voyager has a great mosaic maker AND super-fast focus routines.
Paul
#5 nathanm
nathanm
Posted 13 July 2020 - 11:55 AM
The Voyager mosaic interface looks very nice but it has a limit of 100 tiles.    I would like to do some shots on the order of 200 - 300 tiles.
#6 AtmosFearIC
AtmosFearIC
  • Loc: Melbourne
Posted 14 July 2020 - 06:08 AM
Ive worked on LARGE mosaics with SGP but I’ve found that any more than 55ish targets causes SGP to crash. So in cases like this is either make sure that I’m doing less than 50 panels in a night or make sure to open up a new sequence when the first 50 is complete and start another 50 mid way.
It would require a fair bit of scripting but it could be done in MaximDL.
#7 anon1354732
anon1354732
    Mercury
  • Loc: Turin - Italy
Posted 14 July 2020 - 06:47 AM
we have limited just for resource limits, if you need we can open to 300 if your PC are able to manage
Edited by Leonardo70, 14 July 2020 - 06:47 AM.
  • psandelle likes this
#8 nathanm
nathanm
Posted 18 July 2020 - 03:11 PM
Yes, that would be great, my PC will be able to manage.   I use large SSD disks for captures like this, with a Primaluce Eagle.
#9 nathanm
nathanm
Posted 07 August 2020 - 07:07 PM
Here is an issue that I am running into:   How do you organize the order in which a mosaic is shot?
Most mosaic software has the model that you plan the shot up front, and send the list of positions to the software that is integrating the image capture.   Then at capture time the software will issue a "go-to", and then execute the list of shots.
The mosaic planning software I have played with seems to number the mosaic panels in a simple way, such as top left to bottom right as a zigzag path.
But the reality is that the way you typically want to capture the mosaic is to prioritize the west-most panels because they will set first  (or go to low angle first).   Meanwhile the panels that are all the way to the east will generally get higher in the sky which tends to improve quality.   So these should be deprioritized.
This would be very straightforward for software to do automatically.
I don't know all of the image capture software packages so I don't know if any do it automatically, or if they have some tools to help a user do it.
Also tagged with one or more of these keywords: astrophotography
