Sky Watcher EQ6-R Mount good investment?
mount
10 replies to this topic
#1 darkfinder
darkfinder
Posted 10 July 2020 - 09:48 PM
Hi. I am new and would like some advise on mounts. I am looking at the Sky Watcher EQ6-R.
I have a smaller CEM25.
I would like to get a mount that will hold a little weight,
Would anyone recommend a better mount in the price range of 1300 to 2000?
#2 KTAZ
KTAZ
  • Loc: Scottsdale, AZ
Posted 10 July 2020 - 09:53 PM
I’ve had mine about 60 days and am very happy with it.
  • Jeff L likes this
#3 SeattleScott
SeattleScott
Posted 10 July 2020 - 09:57 PM
It would help to understand if you are visual or AP and how much weight you want to carry.
Scott
#4 gene williams
gene williams
  • Loc: Western Missouri
Posted 10 July 2020 - 10:35 PM
great mount, had one recently but it was killer on the back when moving it.  In the foam insert carrying case, you are looking at 45 lbs in a huge box.  Add another 40 lbs for the tripod and counterweights.  I recently sold it, went down to an AVX that I used for up to 80mm  f/7 refractor for astroimaging with pinpoint stars.  It was overkill for my needs, and was killing my back.
#5 ks__observer
ks__observer
  • Loc: Long Island, New York
Posted 10 July 2020 - 10:59 PM
I have had my EQ6R about 1.5 years.
I use an 8in Newt with camera, CC, filter wheel.
I usually get around .8 to .9 RMS.
I recently had my 70mm Stellarvue on it and had about .6 RMS over a 3 hour run.
Can't say enough good things about it.
Edited by ks__observer, 10 July 2020 - 11:00 PM.
  • Blackbelt76 likes this
#6 darkfinder
darkfinder
Posted 10 July 2020 - 11:21 PM
Thank you for the information.
Kind of shows how new I am.
Would like to mount something like a Rowe-Ackermann Schmidt Astrograph.
But I am still reading.
EQ6-R is rated at 44 lbs.
My Gem25 about 1/2 that.
I just don't want to buy a good mount and then find that there are better ones in close price range.
  • gene williams likes this
#7 bobzeq25
bobzeq25
Posted 10 July 2020 - 11:47 PM
The other alternative is a 16 pound CEM40.  About the same performance, but $2000 with tripod.  You pay for the light weight, less than half the weight of an EQ6-R.
Either the EQ6-R or the CEM40 would handle a C8 RASA (which I own, and have on a CEM60 mount).  But either would be really marginal with a C11 RASA.
You do realize those are astrophotography only, which means you should be posting this on the BII forum?
Edited by bobzeq25, 10 July 2020 - 11:48 PM.
#8 gene williams
gene williams
Posted 11 July 2020 - 11:08 AM
yep, you will definitely need the extra weight capacity of the EQ6-R or the iOptron mentioned by Bobzeq25.  I know from experience the EQ6-R is a great mount, and the carrying handle does make it more manageable.
#9 rayschilke
rayschilke
  • Loc: Lehigh Acres Florida
Posted 12 July 2020 - 10:50 PM
I bought mine for 1379.00 on sale. Best 2000.00 I would spend in a second for the eq6r pro (meaning it is worth much more than I paid). My average total rms error is >.50 and it is a beast. Very solid, quiet, and reliable. Sets up perfect with eqmod and stellarium and I haven't had to even connect the hand controller in 6 months at least.  I can't even say now that my previous mount, an AVX, was anything close to being a real mount. I use mine solely for astrophotography and it works perfect . Only warning is it is heavy! I am 59 and it is a chore to do but I move mine to my pad from the house connected to the tripod. I definitely know I'm carrying something when doing so. I would not use this mount for travelling around to viewing sites often unless you were a big brawny brute.
  • ks__observer likes this
#10 KTAZ
KTAZ
Posted 12 July 2020 - 11:30 PM
Yes, the mount head is heavy (38 lbs), but I can break the whole rig down in 10 minutes pretty easy. If you have a water softener and can lift a 40lb bag of pellets to pour it in your tank, you can handle an EQ6R. And, as somebody else said, it does have a handle on the top of it which makes it much more manageable.
#11 Blackbelt76
Blackbelt76
Posted 13 July 2020 - 02:56 PM
IMO there are not better mounts in this price range.
I've had mine about 6 months and can't say enough great things about it.
There is a EQ6R topic in the "mounts" sub category; lots of good reviews, zero bad reviews unless posted by someone who doesn't understand PA.
I've been shooting a un-modded DSLR at 200mm unguided at 2min 30s without star trailing; that however is after some solid visual PEC training and very good PA.
Yes; it's kinda' heavy at 38lbs, and then (2) 11lb CW's + tripod... thank goodness it does have a carrying handle.
The weight IMO is a good thing..very solid mount even in some wind.
All in all, I can set it up and be ready to observe or shoot in 30 mins.
Edited by Blackbelt76, 13 July 2020 - 02:58 PM.
Also tagged with one or more of these keywords: mount
