number of lines to use in DP test
19 replies to this topic
#1 RichA
RichA
  • Loc: Toronto, Canada
Posted 10 July 2020 - 11:53 PM
I remember someone once told me maximum 3 lines to really get an idea of figure, roughness.  Even using 1 thick band and letting it pan across the image works well.  But I've seen people using 6 and 7 bands.  Is that too many?
#2 Pinbout
Pinbout
Posted 11 July 2020 - 06:09 AM
5 at the most, 2 at the least. 1 if you want to use it like ke to see any zones pop.
  • DAVIDG and Jeff B like this
#3 MKV
MKV
  • Loc: Florida, USA
Posted 11 July 2020 - 08:22 AM
Yes it is. As Pinbout said up to five is considered okay in ATM community. I think five is pushing it.  I don't know where this "rule" comes from, and what "science" it's based on, but there's not doubt that fewer is better. I prefer 2-3 bands max.
Fewer bands show more curvature and zonal errors are also easier to detect.
This can be shown using a 6-inch f/8 parabolic mirror, whose OPD error will be 1/4 wave pvw at ROC. It's obvious with 2 bands and not at all with 8 bands using a 100 lpi screen.
My suggestion is: when you get two or three straight Ronchi bands using the Ronchi test (regardless if it's at ROC or in autocollimation), switch to the knife-edge test for a final assessment.
  • PrestonE and Jeff B like this
#4 Pinbout
Pinbout
Posted 11 July 2020 - 08:39 AM
the title said in DP which is 2x's as sensitive.
and as your working the mirror you want to scale the sensitivity as you get closer to what is possible.
that's why Ceravola uses ronchi in his ross, then ends up using a ke.
its called scoping.
and of course he follows up his ke/ross test with IF which proves with a ke and ross he gets to 1/60~.
  • LarsMalmgren likes this
#5 Jeff B
Jeff B
Posted 11 July 2020 - 08:42 AM
In DPAC I like to use 3 bands, one in the center...because it looks nice...and it gives good resolution, especially towards the edge with a 133 LPI screen.  I also use the screen as a knife edge of sorts to look at the surface.
My example is an 8" F7.5, both in single pass Ronchi and DPAC.  I love DPAC as it tells you almost instantly if you have a good mirror system.  The problem, though, is finding a decent, large aperture flat.  Mine is 12".
Jeff
  • PrestonE, LarsMalmgren, Pinbout and 1 other like this
#6 Pinbout
Pinbout
Posted 11 July 2020 - 08:47 AM
here's a 6in f8 qrt under in dpac, 133lpi. 4 lines and 2 lines. outside focus
and the same 6in f8 qrt under outside RoC, 133 lpi (not dpac...duh)
Edited by Pinbout, 11 July 2020 - 02:18 PM.
  • Jeff B likes this
#7 Jeff B
Jeff B
Posted 11 July 2020 - 09:16 AM
Danny, a dumb question.  How did you do a mirror DPAC without a central obstruction?
Jeff
#8 Pinbout
Pinbout
Posted 11 July 2020 - 09:20 AM
Jeff
computer generated... i could put a hole there is you would like. ha ha ha
but there was a guy in AU said he did... I forget his setup... it was posted here... but that was like 6 -8 years ago when he was working on his 18-20 mirror.
Edited by Pinbout, 11 July 2020 - 09:21 AM.
  • Jeff B likes this
#9 MKV
MKV
  • Loc: Florida, USA
Posted 11 July 2020 - 09:25 AM
How can it look corrected with two bands if it shows undercorrection with four bands?
#10 Jeff B
Jeff B
Posted 11 July 2020 - 09:53 AM
Magic.
  • MKV likes this
#11 MKV
MKV
  • Loc: Florida, USA
Posted 11 July 2020 - 11:48 AM
Magic.
LOL, I trust rayracing. Two-band Ronchi looks curved in autocllimation.
#12 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 11 July 2020 - 12:25 PM
  There is no reason not to test at 3 lines or less,  all  your doing is changing the position of  the grating which takes 3 seconds !  You also want to watch has you move the grating from one side of focus to other and back again. The lines can look pretty straight when stationary but as you watch  them move you can pick up bowing  that you miss when they are stationary. A  well corrected mirror,  lens or optics designed for an object at infinity will show dead straight lines no matter how many and on both side of focus. So as you move the grating from ones side of  the focal plane to other the lines should stay straight just the number will decrease as you approach focus.
    As for testing  a concave mirror without  a hole in the flat,  I do it all the time. You set up the test in a  Newtonian configuration with a diagonal.
               - Dave
  • Pinbout likes this
#13 Pinbout
Pinbout
Posted 11 July 2020 - 02:11 PM
a 6in f8 -1 conic undercorrected by 1/4~ is almost a sphere so straight lines at RoC
#14 Pinbout
Pinbout
Posted 11 July 2020 - 02:16 PM
Outside RoC is Obviously not in dpac
and your showing inside of focus. why? outside always shows what you really have. Inside is always backwards.
Edited by Pinbout, 11 July 2020 - 02:19 PM.
#15 Steve Dodds
Steve Dodds
    Owner - Nova Optical
  • Loc: Utah
Posted 11 July 2020 - 02:21 PM
What I do is get it to 3 lines outside then scoot it inside 3 lines and compare the two.  Back and forth back and forth, significantly more sensitive than just looking at one side.
  • Pinbout and sopticals like this
#16 Pinbout
Pinbout
Posted 11 July 2020 - 03:07 PM
6in f8 1/16th under dpac 133lpi  flipping in and out... inside is about -6.5mm outside is about 5mm
click on the pic to see it animate.
Edited by Pinbout, 11 July 2020 - 03:08 PM.
#17 MKV
MKV
  • Loc: Florida, USA
Posted 11 July 2020 - 04:12 PM
Still the bands are curved. 6-inch f/8 conic -1 at ROC, 133 lpi.
#18 Pinbout
Pinbout
Posted 11 July 2020 - 04:15 PM
A qtr wave under ... if you please
#19 MKV
MKV
  • Loc: Florida, USA
Posted 11 July 2020 - 04:23 PM
6-inch f/8 parabola is quarter wave pvw off at roc as sphere is 1/4 wave pvw off at prime focus.
#20 MKV
MKV
  • Loc: Florida, USA
Posted 11 July 2020 - 04:37 PM
Here is the IF  wavefront analysis for a parabola at roc and sphere at f for 6 in f/8
