Color-correcting a flat panel
#1
Posted 11 July 2020 - 11:00 AM
Click here to view the article
#2
Posted 12 July 2020 - 02:08 AM
Thank you for posting. You are not the first one who does this.
https://www.cloudyni...?hl=+life +hack
My reason for correcting my panel was the strong difference between the channels caused too much noise in the weakest one when using the light pollution / nebula filter. Meanwhile I changed to Lee 1/8 orange to correct towards the white point and away from blue.
At work in the lab we have a large set of Lee foils in all different colors. They come in about A4 size while some other companies have very small patches in this kind of color sample booklets. It is also great to dim down too bright displays in the light lab because the Lee foils are crystal clear.
- Michael Covington likes this
#3
Posted 12 July 2020 - 03:43 PM
Does a flat HAVE to be in color? Is it processed in color when PI does ImageCalibration?
I kind of thought that the flat was just a scaling factor applied to all colors in a light frame. The flat would brighten dim corners and also brighten dark donuts caused by dust on the optics.
#4
Posted 12 July 2020 - 04:39 PM
The flat is applied to all the pixels (red, green, and blue). The color of the flat affects how much light each pixel gets. So yes, the color of the flat has an effect. If it didn't, my whole procedure wouldn't have worked!
- t-ara-fan likes this
#5
Posted 14 July 2020 - 10:01 AM
An alternative is to deal with the problem later on in software. I believe that's what most people do.
I use PixInsight by using ABE or DBE on the stack. They also take out the color cast, as they reduce the light pollution gradient.
Somewhat easier. It would be interesting to see if the hardware alternative is better, perhaps by reducing noise better. If so, I'm surprised that more serious imagers wouldn't be concerned about correcting the flat panel in hardware. Color casts are usual.
Edited by bobzeq25, 14 July 2020 - 10:03 AM.
#6
Posted 14 July 2020 - 10:22 AM
Some people (for sure not Michael!) are dealing with low priced optics that adds fringes to the stars. In that case star based color calibrations can fail. I've processed a lot of that stuff. If you have neutral flat and just can stretch without color calibration things are much easier for a beginner. Some pro might also decide to rely on the cameras color because the results are pleasing even if the star color is scientifically wrong. Color calibration is also tricky if the data are acquired at low altitudes and the air has removed lots of the blue. Sometimes an image full of golden stars looks better than for example the result of PCC which will push up the blue channel all the way up to compensate. I think it is nice to have the option of hardware color as well.
#7
Posted 14 July 2020 - 11:28 AM
I was doing it in software for a long time but decided that in this case it was so extreme that I'd rather color-correct the panel itself.
- bobzeq25 likes this
#8
Posted 16 July 2020 - 01:59 PM
I believe it was the red glow from the giant supernova in M61 which threw off your image haha. Nice image as well. I always get one peak with a considerable gap between the other two. Thanks for the tip.
Les
#9
Posted 17 July 2020 - 03:54 PM
I shoot OSC, so I guess I have this problem too.
Could one just take the blue channel from the flat and make a monochrome version of it?
Or do you need a color flat to go with color images? If that was the case, why not take the blue channel, make a monochrome image, then combine 3 copies of the mono image to make a RGB flat?
Or am I missing something. That does happen LOL.
#10
Posted 18 July 2020 - 10:18 AM
Part of the benefit of flats is that they correct not only vignetting and dust specks, but also PRNU (pixel response non-uniformity). Some pixels are more sensitive than others, and this is one source of grain in pictures. For this to work, the flat needs to involve every pixel. If you used just the pixels of one color and copied their values into the pixels of the other colors, you'd lose this benefit, although you would still correct vignetting and dust specks.
This was not realized in the earlier days of digital astrophotography. It used to be recommended to bin the pixels 2x2 to eliminate color cast; that is, take each RGGB group and make all 4 pixels in it the same. Totally free of color cast, but also not good with respect to PRNU.
- LauraMS, t-ara-fan and Dmisisco like this
#11
Posted 18 July 2020 - 02:02 PM
Agree to Michael. I'd like to add that the problem of not correcting PRNU might be acceptable if you dither and have many subs. Averaging the object form pixels at different places will lower the noise. But why use one channel only? If you want to go that route, debayer the master flat and extract luminance from the result. Use this as your gray flat.
I also would like to add that quite often the artificial light pollution adds an orange color cast to the image that won't go away with a color corrected flat. It only works when the background is dark, I guess.
- LauraMS and Michael Covington like this
#12
Posted 21 July 2020 - 07:35 PM
Hi Michael,
You make a very important point with all channels (RGB or narrowband, when applicable) having to be of equal intensity for proper flat correction with regard to vignetting and uneven response of individual pixels. Because in DSLR the channels are detected by separate pixel populations, a flat of one color should not used for a different channel, as you pointed out, unless just crude correction is acceptable... When channels cannot be adjusted to the same level (e.g. the panel does not emit in far red), the normalization of flat channels will partially address the problem, though the noise will be higher in channels corrected with weaker flat. Building flat source box with extra far-red LEDs will solve this problem, though.
I have a silly question re. images you showed. At least on Canon DSLR, the histogram scale is shown in f-stops (log2) not linear. In that case the peaks of channel histograms in your examples are at about 25% of full dynamic range, instead of typical 50%. Or is Nikon DSLR (?) display different?
Jan
#13
Posted 21 July 2020 - 10:01 PM
Good catch! Those are indeed a little underexposed for flats. It may not make a difference, though.
#14
Posted 24 July 2020 - 05:08 PM
That makes sense. Thanks for all the answers guys.
When I shoot flats with my Spike-A I get 3 distinct peaks in the histogram with my ASI071MC Pro (OSC). Would it make sense to shoot 3 sets of flats, so each of R/G/B was correctly exposed in their respective set of flats. That would I would not be boosting the faintest channel and increasing its noise.
#15
Posted 28 July 2020 - 01:16 PM
Color-balancing the light source would be a way to go. Otherwise, you do not have a choice but to live with a single flat, I am afraid...
#16
Posted 01 August 2020 - 11:39 AM
Thanks for providing this! i went back over all my flats which were all showing a LOT of red and did a color balance on them to simulate what you did here and Voila! whole new ballgame! Now i just need to figure out how much correction is needed on the light box i use to get the proper Gel for it. Thanks so much for helping me figure out something that has been holding me back! I wasn't sure it was wise to have to edit the flats to remove the color, now i know.
- KTAZ likes this
#17
Posted 01 August 2020 - 12:04 PM
Please make sure to post back the type of film you find works best as well as the specific light box you are using.
I have one on order and I am sure that different manufacturers LED's are providing different color saturation, so hopefully this thread will allow us to see some specific color correction films against specific boxes.
It all started with a red galaxy. I took a picture of M61 with my DSLR and calibrated it with PixInsight. It puzzled me that the corrected, calibrated image came out strongly red...
I would love to see three histograms for each of the 3 light levels that most of these boxes offer. Curious if the change in LED intensity changes the color balance.
What box do you have and what color film did you use to correct?
#18
Posted 01 August 2020 - 12:24 PM
Details are in the article, in the Articles section.
#19
Posted 01 August 2020 - 04:32 PM
I actually built my own light box with three 1W LED arrays and a couple of sheets of copy paper in between to make a smooth white surface. However since i made my post i went upstairs to the light box and threw everything together inside to see what the camera was actually showing as the curve and it showed i had too much Magenta and not enough green in it to display properly. So i am buying the Green 15 Gel and will see what that does. If that doesn't work i will get the Green 30 and try it next. However i found that post processing the Flats by adding more green to get a mostly even tone worked the charm!
#20
Posted 01 August 2020 - 04:44 PM
I picked up a sheet of exactly the same gel. I'll report back as soon as this tiny virus lets me image during cloudless New Moon nights.
#21
Posted 01 August 2020 - 05:14 PM
I have a dasher A3 size coming on Monday. I'm planning on using an embroidery ring with several layers of landscape frost material between it and the scope to ensure even dispersion. I'll be curious as to what the histogram looks like.
#22
Posted 03 August 2020 - 09:01 PM
I think if you just clicked the button to unlink channels in STF it would fix all the problems immediately.
#23
Posted 03 August 2020 - 10:14 PM
There are several ways to do it in software. But at that point you have already not used the same amount of the sensor's dynamic range in all the channels. That's why I chose to fix the problem at the source.
- Dynan likes this
#24
Posted 20 August 2020 - 06:15 PM
I saw a guy putting a white t-shirt over his telescope before putting on a LED flat panel like the one on this article. If you put this CalColor 15 Red on it, wouldn't the t-shirt "dilute" the red film? Or is using a white t-shirt even necessary when using the film over the LED panel?
#25
Posted 20 August 2020 - 06:30 PM
The T-shirt doesn't appreciably change the color of the light going through it.
I never use a T-shirt. The LED panel that I'm using is already quite even.
