Looking for the best one shot color to use with my 127 APO
astrophotography beginner CMOS dso equipment imaging refractor
9 replies to this topic
#1 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 12 July 2020 - 03:58 PM
I'm looking to match a one-shot color camera to use with my Explore Scientific ED-127 APO Triplet with FCD1 ED glass. A few of the options that I'm considering in my price ranges are:
ASI 183MC Pro (low $ range)
ASI 1533MC Pro
ASI 1294MC Pro
ASI 1071 Pro (top $ range)
With so many choices I'm not sure if any of these would be the best fit, or if there are others (I'm open to QHY OSC as well). Thanks in advance for your guidance.
#2 bobzeq25
bobzeq25
Posted 12 July 2020 - 04:27 PM
I think it comes down to the 533 and the 071.  The 183 (I own both of them) has tiny pixels, its sweet spot is short fast scopes.  The 294 seems to be a hit or miss proposition.
  • PhotonHunter1 likes this
#3 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 13 July 2020 - 06:42 AM
I think that you want the 071 because of the larger field of view and closer to optimal sampling that you should get with a 1 meter scope. At the same time, though, I wonder if you won't need a flattener with the larger chip. Check with ES and see what they say about the imaging circle.
Rgrds-Ross
#4 Umasscrew39
Umasscrew39
  • Loc: Central Florida
Posted 13 July 2020 - 07:00 AM
The 533 is excellent with very low noise, no amp glow, and great color.  The smaller square sensor is its biggest negative but I've used it on my C11" and 80mm APO triplet getting some nice framing of DSOs.  Another option, if you can squeeze a few more dollars, is the 2600.  This is essentially the 533's big brother with a larger sensor- APS-C.  I have this as well and gives excellent images on an APO triplet.
  • telfish and PhotonHunter1 like this
#5 APshooter
APshooter
  • Loc: Camby, In.
Posted 13 July 2020 - 07:54 AM
The 2600 is really nice if you can swing the extra cost.
  • mewmartigan and PhotonHunter1 like this
#6 Dean J.
Dean J.
  • Loc: Vista, CA
Posted 13 July 2020 - 09:44 AM
ASI 1533MC Pro
ASI 1294MC Pro
As the detector size increases, then the chance of having undesirable star shapes at the edges and corners also increases.  If the star shape distortion is bad enough then you would end up cropping the image... and you had paid extra for that larger detector.
Do you have a flattener to use with the ED-127?  If you don't have a flattener, then my recommendation would be the ASI533.
#7 Dean J.
Dean J.
  • Loc: Vista, CA
Posted 13 July 2020 - 02:29 PM
Also, of the options you mention, I think only the ASI533 is the latest generation back illuminated sensor.
#8 Dean J.
Dean J.
  • Loc: Vista, CA
Posted 13 July 2020 - 03:44 PM
No- so is the ASI2600.  That was the point I was trying to make in my post.  Identical technology- the ASI2600 is just a larger sensor version of the 533.  The only difference besides sensor size is that the ASI2600 also has an IR cut window.
Well, the ASI2600 is a 16 bit camera and the ASI533 is a 14 bit camera. So, they are different in that way too. The ASI2600 wasn’t on the OP’s list.
#9 Umasscrew39
Umasscrew39
Posted 13 July 2020 - 04:12 PM
Well, the ASI2600 is a 16 bit camera and the ASI533 is a 14 bit camera. So, they are different in that way too. The ASI2600 wasn’t on the OP’s list.I realize that
Yes- another difference.  Glad you mentioned it.  I was simply pointing out and correcting your statement,  "I think only the ASI533 is the latest generation back illuminated sensor."  Also, both with no amp glow which is another nice feature.
#10 Dean J.
Dean J.
  • Loc: Vista, CA
Posted 13 July 2020 - 07:12 PM
I actually said - "Also, of the options you mention, I think only the ASI533 is the latest generation back illuminated sensor."  So good luck PhotonHunter1 whichever one you choose.
Edited by Dean J., 13 July 2020 - 10:32 PM.
Also tagged with one or more of these keywords: astrophotography, beginner, CMOS, dso, equipment, imaging, refractor
