Post your 8” Planetary results.
#1
Posted 12 July 2020 - 11:09 PM
- dan777, BKBrown, Justin Fuller and 8 others like this
#2
Posted 13 July 2020 - 12:22 AM
Here are two of mine from when I had a C8 SCT. Mars (2014 opposition) was taken with a 3x Barlow and the old '04 version of the Celestron Neximage. Saturn was taken with a 3x and ZWO asi120MM. I have a decent Jupiter taken with the ZWO somewhere in my computer.
Edited by Justin Fuller, 13 July 2020 - 12:23 AM.
- zjc26138, eros312, BKBrown and 7 others like this
#3
Posted 13 July 2020 - 12:28 AM
I've always enjoyed participating in the small bore (6" and less) topics, and had wondered if there would be interest in starting similar "medium bore" topics, perhaps for 7-10" aperture scopes. I do think people appreciate good images taken with smaller scopes regardless of where they're posted, but having threads to present and discuss images captured within different size-groups of instruments may provide a supportive and less intimidating place than the main Solar System page, especially for those starting out. I also like how the small-bore threads create a lasting historical record of images taken over several years, whereas other topics often disappear down the list within a few days, however good the images within them are. Interested what other "medium bore" imagers think.
Ray
- eros312, BKBrown, Lacaille and 1 other like this
#4
Well, there is a series of threads with results of "small bore" imaging, although that is defined as 6" or less for the purposes of those threads. See links below.
An 8" scope is intermediate, so it is larger than those "small bore" challenges, but still at the low end of a typical planetary imaging rig. You can use the search function, either on this forum, or on Google, to find examples from 8" scopes. One thing to keep in mind, however, is that the results that are typically posted on many websites, including this one, are over selected for truly exceptional images. The "average" image taken with a 14" scope is actually pretty poor quality. It takes the intersection of skill, experience, and location, to produce the best results.
- BKBrown, KiwiRay, gfstallin and 2 others like this
#8
Posted 13 July 2020 - 12:19 PM
As I think somebody else implied above, probably 95% of good images taken with a 12" or 14" could be equaled, if not bettered, by an 8" with excellent seeing. Seeing really is that big a factor.
Take your C8 or Meade 8" to somewhere like Barbados or Curacao and you'd be surprised. The sweet spot for aperture is probably somewhere around the 9" mark (so Celestron had the right idea with the 9.25"). Anything larger will rarely, if ever, be able to take full advantage of its size beyond what typical seeing will allow.
- BKBrown, happylimpet, Lacaille and 3 others like this
#9
Posted 13 July 2020 - 07:00 PM
2018/06/24
Evolution 8" + 2x Barlow (F22) + ASI224MC (no filter-no ADC)
Seeing: 2/5 - ALT: 23°
2018/06/26 UT 21:59 CM1 = 26.3° CM2 = 329.4 CM3 = 206.9° ALT: 23° DIA: 41.6" M: -2.3
Evo 8" @ 18.5 IR-cut > ADC > Barlow 1.5 > ASI224MC
- zjc26138, eros312, TerryWood and 4 others like this
#10
Posted 13 July 2020 - 07:03 PM
Evo 8" @ 17.5 IR-cut > ADC > Barlow 1.5 > ASI224MC
resolution: 0.22 arcs/pix - texp: 7 ms - 110 fps - Gain 350 - Histogram: 70-80 % - 180 s/capture
FireCapture 2.6 > AutoStakkert! 3 (25% frames stacked) > Registax 6
2019-06-25 UT 21:32 --> 2019-06-27 UT 00:11
Seeing: 2.5/5
Transparancy: variable due to veil clouds
ALT: 14° -> 18° -> 16°
DIA 45.6" M: -2.6
Highly compressed GIF:
- zjc26138, eros312, TerryWood and 6 others like this
#13
Posted 14 July 2020 - 04:10 AM
19/08/25
Average seeing.
Evo 8 @ F/17.5 > IR-block > ADC > 1.5 x barlow > ASI224MC
altitude: 18° at transit
2018/08/21
Second shot of Saturn is a beauty!
- roelb likes this
#14
Posted 14 July 2020 - 02:29 PM
[I'll chime in here. I sold my 8SE to my drug dealer (ok, my pharmacist) recently but I had a great time with it. They're great scopes, portable and enjoyable to use. I upgraded to a C11, which doesn't put me at god grade, but I like to think I could turn water into wine someday, as opposed to the other way around most days.
Here are my humble 8SE pics
attachment=1539636:IMG_9537.JPG]
- zjc26138, JMP, BKBrown and 12 others like this
#15
Posted 14 July 2020 - 03:28 PM
Ray
Over the years we have had members asking any number of times about "the next size up" over in the small bore threads. An intermediate challenge series for mid-size scopes might scratch the itch for those folks
Clear Skies,
Brian
Edited by BKBrown, 14 July 2020 - 03:31 PM.
- Jim in PA likes this
#17
Posted 30 July 2020 - 06:20 AM
Must've been when you got the idea to build an invisible observatory!
Edited by Jim in PA, 30 July 2020 - 06:21 AM.
#18
Posted 30 July 2020 - 06:26 AM
19/08/25
Average seeing.
2018/08/21
Your IR image of Saturn is excellent! Showing my noobness here, but have to ask: what is the advantage of using an ADC while imaging with an IR pass filter?
+1 on a "mid-bore challenge" thread for those of us with 7-9" scopes. I just don't have anything worth posting yet!
#21
Posted 14 August 2020 - 03:33 AM
August 13 2020 Canberra Australia C8 in not so good seeing. Used C8 on EVO Alt Az with ZWO 462mc and 2x GSO barlow
Seeing indexes According to Meteoblue 3-4/10, I would guess at the time of my captures from about 4 (Saturn)-5 (Jupiter) /10 High Jet Stream
Given there was high cloud and a heavy cloud mass was expected in a short time, I think if I had a C14 I would not have bothered even trying in these conditions but the C8 (like a C6) is a nice portable scope and not to much effort to put up or tear down!
- zjc26138, Magellanico, HCR32 and 7 others like this
#23
Posted 14 August 2020 - 10:14 PM
Here are some images made with my 8 inch F/15 Schmidt-Cassegrain, the Mars-image of 2003 made with a Philips toucam, recently reprocessed ;-)
conv_m030903f_g3_b3_ap16 B Mars 2003!!.jpg 2003 (Philips Toucam)
22_03_2012_211228waveletPS1.jpg 2012 (DBK21)
conv_Jup_050314_190552_g4_b3_ap37PS.jpg 2014 (ASI120MC)
Having just started out at planetary imaging, this level of detail would be my ideal out come. If I can get close to these in the next 12 months, I will be very happy !
#25
Posted 15 August 2020 - 10:40 AM
I know this is not a contest, but @DORF, wow those look about as good as they could get!
Can you give a few details about your process & setup? e.g. Color or Mono? What camera & Barlow? Are these derotated with Winjupos or just single run shots, etc?
Do you use autostakkert/Registax or are you also doing sharpening in Photoshop (or other tools?)
Seriously these look like the gold standard to aim for.
--Ryan
- mjbetancourt likes this
