Installing a finderscope on my C11 EdgeHD
4 replies to this topic
#1 The_8_Bit_Zombie
The_8_Bit_Zombie
  • Loc: Southern California
Posted 13 July 2020 - 04:03 AM
I'm installing a Baader SkySurfer III onto my C11 EdgeHD. Just double checking that I have all the steps down, because I'm worried about damaging the primary mirror.
So if my understanding is correct, I unscrew the two screws circled in red, place my finderscope bracket over the slot, and just screw the same screws back in? My finderscope bracket is very thin so I don't think I need to use different screws; I'm not sure it even came with any.
Am I missing/messing up anything? Thanks
#2 Umasscrew39
Umasscrew39
  • Loc: Central Florida
Posted 13 July 2020 - 04:27 AM
That is correct.  If the finder scope loosens up, you might need to use longer screws.
  • The_8_Bit_Zombie likes this
#3 The_8_Bit_Zombie
The_8_Bit_Zombie
Posted 13 July 2020 - 04:29 AM
Alright thanks!
Edited by The_8_Bit_Zombie, 13 July 2020 - 04:31 AM.
#4 *skyguy*
*skyguy*
  • Loc: Western New York
Posted 13 July 2020 - 06:40 AM
You're right to be concerned about damaging the primary mirror. Using longer screws could come into contact with mirror, causing a possible chip. It's happened before to others. Take care...
#5 Duncan Kitchin
Duncan Kitchin
  • Loc: Beaverton, OR, USA
Posted 13 July 2020 - 12:14 PM
Yes, there are three pairs of screws available on the rear cell for accessory mounting, including the pair that is intended for mounting a top rail. I have stuff mounted on both the left and right pairs on mine.
If you remove the vent cover and screen temporarily, you can look around inside with a flashlight and get a pretty good idea of how everything is mechanically arranged behind those screws. You should have a bit of clearance, but you don't want to use screws that are that much longer.
