Concrete pier hack question
13 replies to this topic
#1 jambi99
jambi99
  • Loc: Ottawa , Canada
Posted 13 July 2020 - 03:17 PM
Hi there,
would it be acceptable to raise the ground level around the pier to increase the pier depth? I was thinking raising the ground of about 6-8 inches on a 4x4 feet surface to reach the 6 feet recommended frost line depth.
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 13 July 2020 - 04:32 PM
Unless you pack it down real hard, No.
#3 Simcal
Simcal
Posted 13 July 2020 - 04:39 PM
Did a google and Ottawa frost line is 1.8m or 5.9 feet. But that is a building code generalization not taking into account the type of ground, ground water in the site, drainage, exposure to sun etc.   If you're saying you're at 5.4' feet depth, then I wouldn't worry about adding 6".
Even if the pier does move, you can always re-align the mount every year.  It's likely only going to budge during the initial freeze-up in December, and spring thaw in March/April.
Edited by Simcal, 13 July 2020 - 04:40 PM.
#4 bouvier_1
bouvier_1
  • Loc: Sundre, Alberta
Posted 13 July 2020 - 04:50 PM
Lay some 2" rigid insulation down and cover with 6" of dirt
#5 macdonjh
macdonjh
Posted 13 July 2020 - 06:11 PM
I don't think that will work to prevent frost heave.  The soil freezes not only from the top down but would also freeze laterally from the edges of your raised areas.
Curious: why is not digging to the frost line feasible?
#6 piaras
piaras
  • Loc: Niagara Region
Posted 13 July 2020 - 07:06 PM
Foam will work if it covers several feet in radius. We would place a few bales of hay/straw around the well to stop freezing. If you are placing a deck around the pier, use the deck to hold the foam down. I likely would not worry about it. If you are in a windswept area where the snow cover gets blown away and the pier is exposed at ground level then freezing will have better chance of getting to depth. Our water line from the well was at 7 feet and late in the winter, one harsh week of intense cold and no snow cover, it froze. The new line is heat taped.
In my area 4 feet is minimal and my pier is just there. With a deck and Skyshedpod on top, I realign in the spring and over the years it has been only a slight movement.
Pierre
#7 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 13 July 2020 - 10:33 PM
Indeed. Why not dig another 6"? Or a foot just to be sure.  If it is because you hit bedrock that is a good thing.
#8 jambi99
jambi99
Posted 14 July 2020 - 07:27 PM
The auger I rented does not go deeper than 5 feet. Doing the remaining 1 foot is rather challenging considering how narrow the hole is. But I agree, I will try to reach the required (by code) 6 feet by digging deeper. Thanks for your feedback.
#9 piaras
piaras
Posted 15 July 2020 - 09:10 AM
Would seem that the rental place would supply the extension to reach frost line automatically as it is a requirement for the building code.
Pierre
  • t-ara-fan likes this
#10 macdonjh
macdonjh
Posted 15 July 2020 - 09:21 AM
Pierre
+1
#11 jambi99
jambi99
Posted 15 July 2020 - 11:50 AM
Pierre
Yes, the extension was included already. Still limited to 5 feet.
#12 macdonjh
macdonjh
Posted 15 July 2020 - 11:59 AM
Hmm.  When I rented an auger for my pier, I rented two extensions for a total of nine feet.  I wonder if you could rent another extension?
I ended up using all three auger sections, but only going down a bit more than six feet.  I hit a second layer of sand and there wasn't any point in going deeper.
#13 jambi99
jambi99
Posted 16 July 2020 - 09:15 AM
My understanding is that the maximum total bit length was 5 feet so I never asked for anything longer than that. However, you might be right. In any cases, I dug the hole already and I don't want to have to rent another auger. I will have to dig the reaming 6 inches by hand and will 2 inch foam board as suggested above to mitigate the frost. Thanks.
Edited by jambi99, 16 July 2020 - 09:16 AM.
#14 jambi99
jambi99
Posted 21 July 2020 - 08:57 AM
Just an update. I was able to reach a total depth of 6' 4" . Pretty happy with that. Thanks for your help.
  • piaras likes this
