Sequence Generator Pro Location Error
6 replies to this topic
#1 wboeck
wboeck
  • Loc: Nebraska
Posted 13 July 2020 - 07:12 PM
Just recently during plate solving, I have been getting a message of location error greater than 150 px. It keeps going on and on for 6 attempts and then fails. I have ended up deleting sequences and creating new ones using the Mosaic Wizard and it still fails. Then all of a sudden it works. This seems to have happened after I upgraded to the newest version. This is getting annoying.
#2 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 13 July 2020 - 07:41 PM
All of your attempts show the same RA and DEC pixel errors (+- 1 or 2 pixels).  So it looks like the mount is NOT slewing after a solve to recenter.  It's not moving, it's staying in the same place and solving over and over and over again.
I don't use SGP (I use NINA), but is there a setting somewhere you need to turn on to enable slewing to re-center?  Is there a rate to use to do that re-centering (2x, 4x, etc.)?  Those settings might have been lost when the new version was installed...
#3 buckeyestargazer
buckeyestargazer
    Vendor - Buckeyestargazer.net
  • Loc: IN, USA
Posted 13 July 2020 - 07:46 PM
Does your mount use a pointing model?  If so, over time that model can be inaccurate and so SGP tells the mount to "go here" and the mount thinks it went "there" but in reality it's a bit off.  Try clearing the model and don't use a model going forward.
If that's not the problem then I suggest you post your logs on the SGP forum.
#4 Frabog
Frabog
  • Loc: Kontich Belguim
Posted 14 July 2020 - 02:00 AM
Best
I assume that you are using ASCOM and EQMOD to get your mount to work with SGP in which case make sure that automatic pier flip is disabled in EQMOD and also turn mount limit off in EQMOD if these are on you have both in SGP and NINA problems.
#5 wboeck
wboeck
  • Loc: Nebraska
Posted 14 July 2020 - 04:33 PM
I was having problems getting SGP to get a Plate Match. It just kept searching. I started using Astrotortilla to Platesolve. Then SGP quickly seemed to get Pate Matches. Maybe that is why it did not move RA and DEC?
Edited by wboeck, 14 July 2020 - 04:37 PM.
#6 wboeck
wboeck
  • Loc: Nebraska
Posted 14 July 2020 - 04:34 PM
I will probably go to SGP forum. I like Cloudynights better
#7 wboeck
wboeck
  • Loc: Nebraska
Posted 14 July 2020 - 04:35 PM
Best
I am using ASCOM and EQMOD for SGP. I will check those parameters. Thanks
Wayne
Edited by wboeck, 14 July 2020 - 04:36 PM.
