what is the advantages of this configuration ?
13 replies to this topic
#1 delorehal
delorehal
Posted 15 July 2020 - 01:25 AM
Here :
https://explorescien...iant-2221347844
OTA is shorter but requires a big flat mirror instead of a diagonal
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 15 July 2020 - 01:33 AM
Really don't know what the benefit is but at f/4.5 it will sure show serious CA.
  • stevew likes this
#3 sg6
sg6
  • Loc: Norfolk, UK.
Posted 15 July 2020 - 02:18 AM
Looks like they have just added a fairly large diagonal in the tube to direct the light to the focuser. Would therefore I guess make the OTA longer as a normal refractor is OTA+Diagonal whereas this is in effect just OTA with a diagonal inbuilt.
Probably more robust. Disadvantage would be you cannot alter the diagonal, likely cannot use 2" eyepieces as the required position of the eyepiece changes with physical size. OTA I guess has to be used on an AltAz - you cannot reposition/rotate the focuser.
One advantage is the user cannot do a lot to it.
Really looks like someone has rather simply moved the diagonal up inside the OTA, then glued a focuser on the top surface as you still have Lens-tube-diagonal-focuser. Exactly as in a more common refractor arrangement.
#4 futuneral
futuneral
  • Loc: Phoenix, AZ
Posted 15 July 2020 - 02:20 AM
As the description says - it's an "ideal compromise"
I would guess the goals of the design were: 1) refractor 2) not less than 102mm 3) portable 4) dirt cheap
So they figured out the objective lens part of the equation, but that probably required a massive 3" focuser which are expensive. So they cheated by putting a mirror there. Plus a mirror is probably also cheaper than a diagonal.
Edited by futuneral, 15 July 2020 - 02:21 AM.
  • Jon Isaacs likes this
#5 Rutilus
Rutilus
Posted 15 July 2020 - 04:23 AM
Reminds me of something from the book (all about telescopes) by Sam Brown.
#6 PETER DREW
PETER DREW
Posted 15 July 2020 - 04:31 AM
I recently built a 6" F5 binoscope using a similar principle.  I had to do this as the number of prisms necessary for 90 degree viewing angle and IPD adjustment meant that even a 2" diagonal would vignet the light cone, I had to use 3" minor axis diagonal mirrors.  I can't see the same advantage with the Bresser offering apart from shortening the tube.
#7 ButterFly
ButterFly
Posted 15 July 2020 - 05:14 AM
You can't forget the diagonal at home?
  • BFaucett and eblanken like this
#8 SeattleScott
SeattleScott
Posted 15 July 2020 - 11:27 AM
I suspect the goal was keeping the tube short enough to fit the backpack.
Scott
#9 Jon Isaacs
Posted 15 July 2020 - 11:48 AM
I think you nailed it.
At F4.5, vignetting concerns will require a large diameter drawtube. This eliminates the drawtube before the diagonal.  It's cheap..
  • howardcano and eblanken like this
#10 Hesiod
Hesiod
Posted 15 July 2020 - 11:49 AM
It avoid the buyer to waste money by upgrading the diagonal...
  • jeremiah2229 likes this
#11 howardcano
howardcano
  • Loc: Olathe, KS
Posted 15 July 2020 - 12:30 PM
I think this arrangement is a good idea, as long as it's used with mounting rings so the OTA can be rotated to a comfortable position.  As Jon says, it gives better field illumination at low powers than is usually possible with the focuser and diagonal of a "normal" refractor.
My sample of this particular scope didn't impress me optically.  Even when stopped down to 70mm aperture, the image was soft.
Edited by howardcano, 15 July 2020 - 12:32 PM.
#12 junomike
junomike
  • Loc: Ontario
Posted 16 July 2020 - 06:22 PM
Along with the advantages, no one noticed (or pointed out) the huge disadvantage (IMO)......1.25" Focuser.
IMO these OTA's are best at wide field DSO's which will require a 2" eyepiece (to get the widest views).
For that reason I went with the Bresser Cousin which requires a Diagonal but has 2" capability.
#13 stevew
stevew
    Now I've done it
  • Loc: British Columbia Canada
Posted 16 July 2020 - 09:34 PM
Here :
If your looking for a short focus achromat this would be a much better scope in the same price range. https://www.telescop...yCategoryId=331
#14 Steve Cox
Steve Cox
Posted 16 July 2020 - 10:29 PM
No, but you could still forget and leave your eyepieces at home.
