NINA Beginner having trouble retrieving image
14 replies to this topic
#1 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 15 July 2020 - 09:35 PM
I am trying out NINA, but NINA is  having trouble retrieving image from the ASI183mm-Pro.  Error messages:
Error retrieving image data from camera
Camera download failed.
I expect this is due to my total inexperience.  Is there any trick to this?
I have tried a couple of times, but each time NINA:
1) connects to all my equipment (camera, filterwheel, focuser, mount)
2) it slews
3) it seems to platesolve; ASTAP does not work (missing database), but PS2 (which I use for APT) works
4) but I cannot get it to give me a liveview loop to get focus
Tonight it seem to initial capture an image for platesolve, but after that I get errors.  I tried opening Sharpcap to try to give me something to focus, but I have use Sharpcap very little and I did not get that to work.  I thought that connecting Sharpcap may have messed up the connect to NINA.  So I shut down Sharpcap, and still get the NINA error.
I was going to give tonight more time trying to get NINA to work.  The past couple of nights I needed to image before the weather gets bad again, so I gave up and went to APT to capture.
I want NINA to AF, with my Celestron Focus Motor.  I have been having to focus manually w/ Baht mask when using APT.
#2 SilverLitz
SilverLitz
Posted 15 July 2020 - 09:37 PM
When I just tried to disconnect the ASI183, NINA hangs up (Not Responding).
#3 nimitz69
nimitz69
  • Loc: A barrier island 18 miles south of Cocoa Beach
Posted 15 July 2020 - 09:48 PM
Sounds like camera driver issues. Which ASCOM driver are you using for the camera?
#4 khursh
khursh
Posted 15 July 2020 - 10:05 PM
NINA has issues with using 32 bit drivers with the 64 bit application
#5 ezwheels
ezwheels
  • Loc: Oakland, CA.
Posted 15 July 2020 - 10:18 PM
Use the native ZWO driver if you have it installed. If you don't have it installed you should download it and use it. NINA should also ship with the native support for ZWO cameras so updating NINA should also update the native driver.
If you are not already I would recommend to use the latest 1.10b build. It is stable and pretty much done. In general it is best to always match drivers to the NINA version. So if you use the x86 NINA you need 32 bit drivers. If you use the x64 NINA get 64 bit drivers. I would also recommend downloading the G17 database for ASTAP. ASTAP is incredibly fast and robust.... like a couple of seconds to plate solve fast.
Lastly, I would recommend joining the Discord and asking for help there. Folks are active pretty much 24/7 and you will get much better help with technical issues and often in real time.
I definitely feel that NINA and the community around it are worth the effort.
  • DSOs4Me likes this
#6 SilverLitz
SilverLitz
Posted 15 July 2020 - 10:36 PM
#7 tkottary
tkottary
  • Loc: SunnyVale ,CA
Posted 15 July 2020 - 10:40 PM
What version of Nina ?
#8 SilverLitz
SilverLitz
Posted 15 July 2020 - 10:51 PM
I disconnected the camera from APT and reopened NINA and it connects, and captures.  It seems to have problems if other programs are connected to the camera.
But 5s (L, unity gain) shot shows almost nothing (magic stretch clicked) compared to APT whose autostretch clearly shows many stars.  Even 30s shows next to nothing.
Slewing does not seem to automatically platesolve and iterate until it zeroes in.
#9 SilverLitz
SilverLitz
Posted 15 July 2020 - 10:52 PM
1.10 RC005, a nightly from a few nights ago
#10 SilverLitz
SilverLitz
Posted 15 July 2020 - 10:55 PM
I am going to shut it down for the night, we are starting to get clouds and forecast has rain chance for the next few days.
I am going to take the scope/cam/electronics inside and cover the mount w/ large plastic trash can + tarp.
#11 TXDigiSLR
TXDigiSLR
  • Loc: Dallas, TX
Posted 15 July 2020 - 11:00 PM
Check your cable.  I had the same issue with my 1600mm Pro.   Every now and then it just gave me the same errors.  I changed cables and haven't had the problem since.
#12 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 15 July 2020 - 11:07 PM
As above -- don't use the ASCOM driver.  Use the native driver (it will say "ZWO ASI 183MM Pro" in the NINA dropdown).
I have the same camera, and it's working fine in NINA for over a year...same driver version as you have above (1,15, 0617).
So do check your cables...
A 1-sec exposure at gain 100 offset 10 on Vega shows Vega and around 80-100 other stars with autostretch on.
You will indeed have problems connecting the any ASI camera to 2 different apps at the same time (not a NINA thing, an ASI driver thing).  And you might have to reset (power off, remove USB cable, cable back in, power on) the camera after another app has been using it before NINA can.  One app at a time for cameras.
Good luck :)
  • Aaron_tragle likes this
#13 colinrm
colinrm
  • Loc: Akron, Ohio
Posted 15 July 2020 - 11:08 PM
I have the same error sometimes.  Usually, I just need to manually take a few images and they start coming through.  Switching between programs using the same camera always shows that error.
#14 TXDigiSLR
TXDigiSLR
  • Loc: Dallas, TX
Posted 16 July 2020 - 01:11 AM
I've recently only been using NINA for everything.  In the past I used Sharpcap to Focus and Polar Align.    I found out as others have said, if I use another app that connects to the camera then try to use NINA, I get weird errors.
I always shut every other app down completely, and then start NINA fresh and connect everything from within NINA.  Sometimes I'll even reboot before starting NINA.
The good thing is that NINA's autofocus seems to work great for me, and once you're focused there really is no need to drastically refocus ever again.  Maybe just a minor adjustment here or there.
#15 kisstek
kisstek
Posted 16 July 2020 - 01:30 AM
Make sure you have version 1.5 of the ASCOM driver for the Celestron focus motor. The previous version (1.3, which identifies itself as version 6.2) doesn't work with the latest NINA release candidates. There's some communication problem that v1.5 fixes.
Oh, and slewing doesn't plate solve automatically. You can run plate solving manually in the Image tab, middle window with a tab labeled "Plate Solving". Hit the "play" button in the middle of the window to start it.
Or you can setup the sequence to plate solve at the beginning of the sequence, along with autofocus. (which is on another tab in the middle window if you want to start a focusing run manually)
I've been using APT for the past two years. I like APT. I'll really like APT when it has autofocus, maybe later this week. But NINA is pretty useful too. I haven't decided which I'll be using going forward. But I'm using NINA right now.
  • SilverLitz likes this
