Tracking Neowise
2 replies to this topic
#1 niktnowy
niktnowy
Posted 16 July 2020 - 08:55 AM
I was wondering if there is any way I could track this Comet with ZWO Asiar based software? If not what would be the best way to do so?
Currently I use HEQ5-Pro mount.
Thank you
#2 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 16 July 2020 - 11:20 AM
While the comet is not moving the same direction/speed as the apparent motion of the stars, it's close enough that for imaging purposes, just using normal sidereal tracking is fine.  It would only be a problem if you're going to image it for several hours (which isn't likely).
If instead of "tracking" you mean "finding" it...
Go here:
https://theskylive.com/c2020f3-info
It will tell you the RA/DEC coordinates of the comet at any time.  You can enter your location data if you want to -- but that's not necessary to get RA/DEC coordinates (which are the same anywhere).  Doing so *will* tell you when it rises above your local horizon, etc.
Get the coordinates.  Type them into the place to GOTO specific RA/DEC coordinates.  Have your mount GOTO those coordinates.  Done.
For the ASIAIR, enter the coordinates Target: RA() and DEC() boxes below, then hit GOTO.
  • Hypoxic likes this
#3 niktnowy
niktnowy
Posted 16 July 2020 - 01:41 PM
@OldManSky - Thanks a lot.  That is amazing news,  Thank you
  • OldManSky likes this
